kpfoten |
Member ![]() ![]() Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None ![]() |
Cooler weather in Upper Michigan... Yesterday when it was warm, my '73 1.7 D-Jet seemed to idle well. Today, a bit cooler out. The car starts up and idles for 3 minutes or so (when cold) and then dies. I can start it up and if I keep the idle up I can keep it running, otherwise it will die. I'm assuming the CSV quits at a certain point and It's still not getting enough gas to keep running? I thought it might have something to do with the cold weather? Anyone else familiar with this? I will check the d-jet site (pbanders?) site now.. |
kpfoten |
Quick update on the car: Checked the valves--all good. Marked my fan to help when I have a helper to check the timing. I dialed the dwell in at about 46 degrees. Still runs and dies. Will check timing tomorrow (hopefully). Does anybody have a good setup for loosening/tightening the dizzy bolt? I've always had a tough time getting a wrench in there... |
Lo-Fi Version | Time is now: 26th June 2024 - 06:23 AM |
