kpfoten |
Member ![]() ![]() Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None ![]() |
Cooler weather in Upper Michigan... Yesterday when it was warm, my '73 1.7 D-Jet seemed to idle well. Today, a bit cooler out. The car starts up and idles for 3 minutes or so (when cold) and then dies. I can start it up and if I keep the idle up I can keep it running, otherwise it will die. I'm assuming the CSV quits at a certain point and It's still not getting enough gas to keep running? I thought it might have something to do with the cold weather? Anyone else familiar with this? I will check the d-jet site (pbanders?) site now.. |
kpfoten |
Thanks--I'll get one up ASAP. I estimated 5 degrees from the Pelican DIY printout for the fan. Then I set static timing at 5 degrees by rotating the dizzy counterclockwise and picking up where I have 12V from the coil to the #1 plug. It started up and had good throttle response, but still wouldn't hold idle. I DID notice that if I had my airbox disconnected from the intake the throttle response was better than when I connected it. Maybe when everthing is hooked up it's running too rich because it's not getting enough air? Just a thought. Anyway, I think the dizzy is now close. Something else may be the culprit? |
Lo-Fi Version | Time is now: 26th June 2024 - 06:28 AM |
