MikeSpraggi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region ![]() |
Is anyone out there running 944 Turbo front brake calipers on their 914? I have struts with 3.5" spacing, but what else do I need to make these work up front ... rotors, proportioning valve, etc.? Rear calipers will be SC.
Thanks |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve.
Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. |
MikeSpraggi |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve. Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. Even with the 911 3.5" spaced struts I will still need to do some offset drilling of the caliper mounting holes? |
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve. Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. Even with the 911 3.5" spaced struts I will still need to do some offset drilling of the caliper mounting holes? Yes I think the spacing is 3.750 or close to that. The right way to do this is have the holes welded up and then machine the correct spacing. The backyard way is to elongate the holes to fit. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:11 PM |
