914 Front Brake Upgrade, 944 Turbo Calipers |
MikeSpraggi |
Nov 14 2009, 03:29 PM
Senior Member Group: Members Posts: 781 Joined: 7-February 05 From: Silver Spring, Md Member No.: 3,570 Region Association: MidAtlantic Region |
Is anyone out there running 944 Turbo front brake calipers on their 914? I have struts with 3.5" spacing, but what else do I need to make these work up front ... rotors, proportioning valve, etc.? Rear calipers will be SC.
Thanks |
ClayPerrine |
Nov 15 2009, 04:46 AM
Life's been good to me so far..... Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve.
Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. |
Gary |
Nov 15 2009, 12:33 PM
Senior Member Group: Members Posts: 744 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region |
Actually, the 944 turbo calipers are fairly easy to put on the front of your car. It just takes offset drilling of the caliper mounting holes. A 19mm master cylinder will work fine with them, and the SC rears will be a good match without a proportioning valve. Use 911 Carrera front rotors with them. I had a set on my car,but switched to Boxster brakes. I'm running this setup on mine. Rich Johnson supplied the modified struts as part of a 5-lug upgrade "kit": koni red strut inserts, calipers, carrera discs, drilled rears, etc. Even loaned me the tool to change the rear bearings. Stops great. Given the wide availability of boxster parts and lack of 944T/C2 caliper rebuild kits, I'd probably go this route today. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:48 PM |
