Does fuel pump (injection) cut off if clogged?, YES i searched and read all 20 pages |
jsayre914 |
Nov 15 2009, 11:56 AM
Speed Up !!! Group: Members Posts: 3,199 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
On a bosh fuel pump (3 tit) does it cut out if it cannot get fuel?? I realize if it is intermittant it is probably a loose connection, loose or bad relay, loose pin on board, or dirty fuse on board, etc.
i am at work, and i am not so sure i will make it home tonight, i have a few tools, but no electrical stuff with me. i was wondering .... what would the pump do with good power and a clogged line?? i made it half way to work and the pump cut out 3 times within 1 min, then dead. i pulled over checked the pump and all connections tight. i tried to start it 4-5 times, heard the pump run for 1 sec then dead. crawled under and shook the filtre and banged on the pump. it started but would not idle. i then loosend the clamp holding the pump and turned it upside down. car started and kept strong at high idle but started to choke below 3500 rpm. I risked the drive into work, and made it idling between 3500 and 4500, it would start to cut out and i would downshift jump the rpm and it was ok again. welcome to my life |
jsayre914 |
Nov 15 2009, 03:06 PM
Hey,
does anybody have a fuel filtre to drop off at the karmic connection tonight? (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 12:14 PM |
