jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
On a bosh fuel pump (3 tit) does it cut out if it cannot get fuel?? I realize if it is intermittant it is probably a loose connection, loose or bad relay, loose pin on board, or dirty fuse on board, etc.
i am at work, and i am not so sure i will make it home tonight, i have a few tools, but no electrical stuff with me. i was wondering .... what would the pump do with good power and a clogged line?? i made it half way to work and the pump cut out 3 times within 1 min, then dead. i pulled over checked the pump and all connections tight. i tried to start it 4-5 times, heard the pump run for 1 sec then dead. crawled under and shook the filtre and banged on the pump. it started but would not idle. i then loosend the clamp holding the pump and turned it upside down. car started and kept strong at high idle but started to choke below 3500 rpm. I risked the drive into work, and made it idling between 3500 and 4500, it would start to cut out and i would downshift jump the rpm and it was ok again. welcome to my life |
jsayre914 |
i just tried the jumper test. + to coil and - to battery neg.
car ran perfect, no hesitating, or choking. i let it run 10min and goosed it now and then. perfect. so now what does it all mean. A) it could be a electrical short. dual resistor, wire, connector on relay needs bent? (IMG:style_emoticons/default/cool.gif) it could be the fuel pump. acting perfect now, just waiting till i get 1hour from home to act up again, or die forever. C) (new filter) could have solved the problem?? i will play again little later. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
i just tried the jumper test. + to coil and - to battery neg. car ran perfect, no hesitating, or choking. i let it run 10min and goosed it now and then. perfect. so now what does it all mean. A) it could be a electrical short. dual resistor, wire, connector on relay needs bent? (IMG:style_emoticons/default/cool.gif) it could be the fuel pump. acting perfect now, just waiting till i get 1hour from home to act up again, or die forever. C) (new filter) could have solved the problem?? i will play again little later. Tell me slower. You jump the coil and the car runs fine? Rich |
Lo-Fi Version | Time is now: 25th June 2024 - 01:11 AM |
