Secret on getting CV loose, What is it? |
damnfiknow |
Nov 17 2009, 09:15 PM
Member Group: Members Posts: 77 Joined: 25-October 09 From: Texas Member No.: 10,980 Region Association: None |
After using impact wrench to get the peskie bolts loose, I can't get the CV to turn loose of the wheel hub. "Gentle" tap on the ones at the transmission did the trick there. But can not get an good angle on the outboard ones. HELP
GeorgeRud |
Nov 17 2009, 09:23 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
If it's an option for you, why don't you simply remove the large nut that holds the stub axle on and remove the entire assembly. You can then easily work on the halfshaft on the bench.
Just don't roll the car around with the stub axle removed, you'll probably ruin the bearing. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:28 PM |
