jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
On a bosh fuel pump (3 tit) does it cut out if it cannot get fuel?? I realize if it is intermittant it is probably a loose connection, loose or bad relay, loose pin on board, or dirty fuse on board, etc.
i am at work, and i am not so sure i will make it home tonight, i have a few tools, but no electrical stuff with me. i was wondering .... what would the pump do with good power and a clogged line?? i made it half way to work and the pump cut out 3 times within 1 min, then dead. i pulled over checked the pump and all connections tight. i tried to start it 4-5 times, heard the pump run for 1 sec then dead. crawled under and shook the filtre and banged on the pump. it started but would not idle. i then loosend the clamp holding the pump and turned it upside down. car started and kept strong at high idle but started to choke below 3500 rpm. I risked the drive into work, and made it idling between 3500 and 4500, it would start to cut out and i would downshift jump the rpm and it was ok again. welcome to my life |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
I am confused.
If this is a fuel pump issue or an ignition issue? Fuel pump is powered by the "other" relay pack, not the funky looking one for the injectors. I think that the other relay pack gets its power from via the injector relay pack...cant remember. Find the 12vdc feed wire for the relay pack near the battery and run a wire right to the battery. It still gets its trigger from the key. Rich |
jsayre914 |
I am confused. If this is a fuel pump issue or an ignition issue? Fuel pump is powered by the "other" relay pack, not the funky looking one for the injectors. I think that the other relay pack gets its power from via the injector relay pack...cant remember. Find the 12vdc feed wire for the relay pack near the battery and run a wire right to the battery. It still gets its trigger from the key. Rich sorry, i am still learning. if it was a ignition issue, few days ago when it was stalling out on the highway, the engine was still firing, it was not getting any gas. if it were a ignition issue wouldnt it have died completly. wouldnt it also illuminate the light on the panel?? just asking. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:07 AM |
