Does fuel pump (injection) cut off if clogged?, YES i searched and read all 20 pages |
jsayre914 |
Nov 15 2009, 11:56 AM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
On a bosh fuel pump (3 tit) does it cut out if it cannot get fuel?? I realize if it is intermittant it is probably a loose connection, loose or bad relay, loose pin on board, or dirty fuse on board, etc.
i am at work, and i am not so sure i will make it home tonight, i have a few tools, but no electrical stuff with me. i was wondering .... what would the pump do with good power and a clogged line?? i made it half way to work and the pump cut out 3 times within 1 min, then dead. i pulled over checked the pump and all connections tight. i tried to start it 4-5 times, heard the pump run for 1 sec then dead. crawled under and shook the filtre and banged on the pump. it started but would not idle. i then loosend the clamp holding the pump and turned it upside down. car started and kept strong at high idle but started to choke below 3500 rpm. I risked the drive into work, and made it idling between 3500 and 4500, it would start to cut out and i would downshift jump the rpm and it was ok again. welcome to my life |
underthetire |
Nov 18 2009, 05:53 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
ooooh, i can answer this one, lost my pump on the bay bridge. Ignition, tach drops right away, bounces around. Fuel pump, still sees RPM, so the tach just kinda keeps up with the motor. Either way, no lights on the dash until the motor actually completely stops.
jsayre914 |
Nov 18 2009, 05:58 PM
ooooh, i can answer this one, lost my pump on the bay bridge. Ignition, tach drops right away, bounces around. Fuel pump, still sees RPM, so the tach just kinda keeps up with the motor. Either way, no lights on the dash until the motor actually completely stops. how did you get off the bridge. (i also have those thoughts on really long bridges)?? my last fuel pump went up on the highway, super traffic jam construction. only one lane open and nowhere to pull off. pump died. It totally sucked. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:28 PM |
