wevo shift linkage redo |
brp986s |
Nov 18 2009, 08:28 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
I thought this was going to be a rant, but reconsidered. I like to look at others projects - time to return the favor. Anyhow, I'm putting together a 3.2 with 915 wevo. As a diy'er, I don't have fab capability, so I bought a shift linkage from a well known vendor. I think the product needs improvement. The kit includes front and rear bars, 2 u-joints, and a firewall bearing.
Above is a u-joint from the kit. It is like the joints used in the steering linkage. It is drilled and tapped for a cone screw on one end. Problem is, the screw only engages 1.5 threads before bottoming in the wevo input shaft. Below is a wevo joint I bought to replace it. Using a wevo joint, you'll get 4.5 threads engagement. |
Cevan |
Nov 19 2009, 05:24 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Where did you get that shift boot? The stock one won't completely cover my RennShifter, and yours looks like it would.
JWest |
Nov 19 2009, 05:30 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Lo-Fi Version | Time is now: 30th December 2024 - 05:23 PM |
