wgwhitney2 |
What the What? ![]() Group: Members Posts: 35 Joined: 8-November 09 From: Rocklin, CA, Northern California Member No.: 11,020 Region Association: Northern California ![]() |
Anyone have a work around for a AAR? Mine is sitting upside down in penetrating oil as I hope and pray that the cylinder becomes unstuck. In the meantime, has anyone successfully grafted another AAR device? My 1973 1.7L needs a little help when she's cold.
As I research the subject I see where Bosch made a bunch of FI systems for various auto manufacturers around the world, and I cannot help but think one of those bits would do the job my 0280-014-007 does when healthy? |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
You could use a 12vdc solenoid to open a vac. line. Grainger has them for 25 bucks. would be open or closed though, nothing in between.
wgwhitney2 |
You could use a 12vdc solenoid to open a vac. line. Grainger has them for 25 bucks. would be open or closed though, nothing in between. Yeah, I was noodling through that idea myself...could you put a potentiometer in the circuit and control travel of the valve piston on a solenoid air valve? Control the POT from inside the car...no cables needed? Just getting a AAR for a 924 is probably the easiest, but not as much fun. |
underthetire |
You could use a 12vdc solenoid to open a vac. line. Grainger has them for 25 bucks. would be open or closed though, nothing in between. Yeah, I was noodling through that idea myself...could you put a potentiometer in the circuit and control travel of the valve piston on a solenoid air valve? Control the POT from inside the car...no cables needed? Just getting a AAR for a 924 is probably the easiest, but not as much fun. No, in a nutshell. A solenoid by nature is open or closed. Variable voltage would only make it start to get hot, then as the voltage increased to the minimal coil voltage, it would just trigger. You can get a servo valve, but it would cost way to much. You possibly could hook up a small RC servo as a variable idle stop, using a pot or even a small servo driver board. Or use one to open a ball valve, as long as it wasn't a stiff one. Lots of ideas, not a lot of time. |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:46 PM |
