> WOW, my "solid" car aint so solid, but now it is solid!, It is off jack stands!!!
wayne1234
post May 5 2009, 08:32 PM
Well, I decided to look into the new car more that I got from a member on here. there was a trunk floor repair that left a little to be desired. I tried using flux cored mig welding and didnt have much luck, so yesterday I got a tank and some gas @ $200 (ouch) and I was doing some survey work on the front trunk. Let me say I was way too excited to get my car and I looked underneath and saw a couple of rust throughts on the passenger side near the rear but the "longs" where I spent most of my 5 minutes looking was solid. and I though no big deal just a couple of pan spots. and under the new battery tray looked solid from the engine compartment. well under the battery tray "hell hole" was described as" not perfect". there is a piece of metal screwed over the bad stuff. making it appear solid. Then the big suprise, there has been por15 used on the motor mount I thought it looked real rough and when i pushed on it with my finger oops a hole. some poking with a screw driver resulted in the hole you see. the I looked further back at the arm that goes to the rear suspension and it is also por15 with a odd look . more poking and you guessed it a hole. I guess some one thinks por15 is structural. NOT,,, Well I dont mind documenting this because I will fix it right. but hopefully my eagerness to finally get my 914 will make someone else take a second look at the car they are looking at. Mine look great in photo's and even pretty good in person. but it had a dark secret. Now the Real question on the motor mount and (trailing arm mount?) guess that's what its called. what should I paint the back of the metal with and what gauge should I use, should I make drain holes so It wont hold water in the future? Im gonna try to do all this welding with the motor in the car. I fear I will never get the car back together if I take out the motor. Thanks for all your input. Wayne
Ferg
post Nov 20 2009, 02:08 PM
(IMG:style_emoticons/default/blink.gif) were those lower gaps/holes covered with bondo and sealer or did you already start to cut away bad metal ?
Ferg
wayne1234   WOW, my "solid" car aint so solid, but now it is solid!   May 5 2009, 08:32 PM
wayne1234   here some more pics... And check out the "All...   May 5 2009, 08:38 PM
wayne1234   here is more :headbang:   May 5 2009, 08:41 PM
SirAndy   What year is your car? The color should have been...   May 5 2009, 08:41 PM
wayne1234   Its a 74 one year older than me. yep :confused: l...   May 5 2009, 08:47 PM
SirAndy   Its a 74 one year older than me. yep :confused: ...   May 5 2009, 10:00 PM
wayne1234   My fear is I wont ever get her back together if I ...   May 5 2009, 08:51 PM
wayne1234   how can I tell what trans I have   May 5 2009, 10:28 PM
Dave_Darling   how can I tell what trans I have Where does the...   May 5 2009, 11:13 PM
charliew   You need to move back and manualy focus your camer...   May 5 2009, 11:03 PM
wayne1234   Thanks for the input, tools are not the problem. I...   May 5 2009, 11:28 PM
wayne1234   Well I have been busy here is the good and the bad...   May 5 2009, 11:57 PM
wayne1234   by the way looks like side shift linkage on driver...   May 6 2009, 12:15 AM
wayne1234   couple of better pics   May 6 2009, 12:19 AM
veltror   Mine was yellow,...........once   May 6 2009, 03:53 AM
Dave_Darling   For a side-shift car, your motor mount bar should ...   May 6 2009, 08:45 AM
mudfoot76   :wttc: If you haven't dropped engine yet and...   May 6 2009, 08:46 AM
Vacca Rabite   If your engine mount is rusted out, you are going ...   May 6 2009, 09:03 AM
wayne1234   Thanks for the offer mudfoot. i looked at your sig...   May 7 2009, 05:17 PM
Larouex   That's a heartbreak and a totally misrepresent...   May 7 2009, 11:38 PM
wayne1234   I'm gonna save her, i got all the bad out on t...   May 8 2009, 05:32 PM
highways   It's good you're motivated to save her. Th...   May 9 2009, 03:32 PM
veltror   Soda blast it rather then walnut shells, much les...   May 10 2009, 11:03 AM
charliew   When a unibody car has a lot of rust that is obvio...   May 10 2009, 01:07 PM
wayne1234   Well I have decided to go the easier route and dro...   May 11 2009, 08:41 PM
wayne1234   here is the mini sand blaster and my bike   May 11 2009, 08:44 PM
wayne1234   Progress :bump: .. Well after the girlfriend got h...   Oct 9 2009, 11:29 PM
wayne1234   what was left of the motor mount pics   Oct 9 2009, 11:49 PM
wayne1234   oops a little big lets try this   Oct 10 2009, 12:21 AM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Oct 10 2009, 12:33 AM
wayne1234   with the inner fender well in :headbanger: remin...   Oct 10 2009, 12:38 AM
wayne1234   The girlfriends car that kicked the Porsche out of...   Oct 10 2009, 12:50 AM
wayne1234   Feels like I'm making some real progress. Wha...   Oct 10 2009, 11:19 AM
SirAndy   Feels like I'm making some real progress. Wh...   Oct 10 2009, 12:42 PM
Dave_Darling   In my experience, lighter colors show the dirt a l...   Oct 10 2009, 01:30 PM
faux916   Wayne, is that the car that was in the classifieds...   Oct 10 2009, 02:42 PM
rick 918-S   Wayne, is that the car that was in the classified...   Oct 10 2009, 02:52 PM
wayne1234   WTF indeed,,,, Yep I bought it off a member on her...   Oct 11 2009, 02:15 AM
veltror   Keep going, mine is/was bad and I am still with it...   Oct 11 2009, 06:07 AM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Oct 31 2009, 08:19 PM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Oct 31 2009, 08:27 PM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Oct 31 2009, 08:31 PM
FourBlades   Your car is looking great, man. :trophy: You w...   Oct 31 2009, 08:35 PM
wayne1234   Finally got some more work done with a buddy helpi...   Oct 31 2009, 08:38 PM
914_teener   You are a true Hoosier... my Mom is from Indy....k...   Oct 31 2009, 08:44 PM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Oct 31 2009, 08:52 PM
wayne1234   Well I'm waiting on engine parts :bullshit: ...   Nov 18 2009, 10:23 PM
rick 918-S   I ran a metal fuel line through the tunnel but I e...   Nov 18 2009, 11:54 PM
wayne1234   OH NO,,, There is more welding in my future... Wel...   Nov 19 2009, 10:39 PM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Nov 19 2009, 10:42 PM
Ferg   :blink: were those lower gaps/holes covered with...   Nov 20 2009, 02:08 PM
wayne1234   No they were covered by that light blue metal piec...   Nov 20 2009, 04:49 PM
wayne1234   Getting it sorted out   Nov 25 2009, 05:51 PM
wayne1234   Keep the comments coming   Nov 25 2009, 05:53 PM
wayne1234   Welded up a couple of bondo spots that had nothing...   Dec 4 2009, 02:56 PM
SirAndy   Oh man, every time you post another picture, it ju...   Dec 4 2009, 03:01 PM
oz371   Oh man, every time you post another picture, it j...   Feb 12 2010, 01:51 PM
wayne1234   Also major progress.. We got the passenger inner f...   Dec 4 2009, 03:07 PM
wallys914   Also major progress.. We got the passenger inner ...   Dec 5 2009, 03:03 AM
wayne1234   Well we got the front slope nose back into shape t...   Dec 5 2009, 12:07 AM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Dec 5 2009, 12:09 AM
charliew   The guy that sold you that car should have his nam...   Dec 5 2009, 11:57 AM
wayne1234   Lots of progress :D ... Well I tore into the passe...   Dec 10 2009, 12:45 PM
SirAndy   It Was purchased off a member on here "1bad9...   Dec 10 2009, 01:03 PM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Dec 10 2009, 12:47 PM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Dec 10 2009, 12:50 PM
Rand   Kudos to you Wayne for showing such a good attitud...   Dec 10 2009, 01:02 PM
wayne1234   Yeah he said it was welded but.... He must have me...   Dec 10 2009, 01:14 PM
6freak   I feel for ya man.your a better man then me cause ...   Dec 10 2009, 03:22 PM
wayne1234   Wow we have been putting in the hours on the 914. ...   Dec 12 2009, 02:25 AM
wayne1234   Before After :smash: Some of the PO handy work...   Dec 12 2009, 02:35 AM
wayne1234   Success :trophy: The start of the sill plate mes...   Dec 12 2009, 02:41 AM
wayne1234   This is grafic :evilgrin: He though to hims...   Dec 12 2009, 02:50 AM
wayne1234   New metal :cheer:   Dec 12 2009, 02:53 AM
jd74914   Its looking great Wayne! The slope nose is rea...   Dec 12 2009, 08:23 AM
Gint   Sheeesh.... What a mess. :agree: Great work c...   Dec 12 2009, 08:53 AM
wayne1234   Got the drivers side all blocked out! Here i...   Dec 13 2009, 06:09 PM
wayne1234   Well me and my buddy have still been putting int t...   Dec 23 2009, 12:56 AM
Spoke   Good job. I'm going through some rustoration m...   Dec 23 2009, 10:54 AM
wayne1234   Alot more progress, I finally finished the paint, ...   Jan 2 2010, 12:10 AM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Jan 2 2010, 12:13 AM
sendjonathanmail   Try 914ap.com for your carpet and interior needs. ...   Jan 2 2010, 08:20 AM
wayne1234   I'm really happy with how the paint is coming ...   Jan 3 2010, 03:08 PM
Ferg   Wow, you've been busy, great work! If I w...   Jan 3 2010, 04:12 PM
rick 918-S   Looks like your on top of it now! :clap:   Jan 3 2010, 08:16 PM
Sleepin   Looking good! I wish I could do paint and body...   Jan 3 2010, 09:30 PM
plymouth37   Paint looks great! keep up the good work!   Jan 3 2010, 10:25 PM
wayne1234   Engine is almost totally together :cheer: couple ...   Jan 6 2010, 02:12 AM
wayne1234   Progress has been SLOW.... the engine is in :D I m...   Feb 12 2010, 12:28 PM
wayne1234   RE: WOW, my "solid" car aint so solid, but now it is solid!   Feb 12 2010, 12:40 PM
wayne1234   Almost forgot I got the bumpers on!! here...   Feb 12 2010, 12:45 PM
wayne1234   Also I got the parking brake installed and working...   Feb 12 2010, 12:56 PM
SirAndy   I know its a small piece , but it was curve and w...   Feb 12 2010, 02:15 PM
6freak   ton of work ...nice job .....rubber buggy bumpers ...   Feb 12 2010, 01:44 PM
wayne1234   There is always that :D I thought about it after...   Feb 12 2010, 02:26 PM
PanelBilly   Did I understand you correctly? You sanded and the...   Feb 12 2010, 02:40 PM
wayne1234   Yeah there was a crack in mine So I used the hobby...   Feb 12 2010, 03:09 PM
wayne1234   Still making small progress, I got almost all the ...   Mar 6 2010, 12:01 AM
wayne1234   Then the new mod... I realised I have no front pa...   Mar 6 2010, 12:08 AM
FourBlades   Your car is looking good man. I like your turn si...   Mar 6 2010, 06:53 AM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 20th April 2025 - 09:08 AM
