wayne1234 |
Member ![]() ![]() Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None ![]() |
Going for the fuel line replacement, what is available at local auto parts store, do I just use brake lines? I know you can order a stainless steel set from a vender (forgot who) but I'm looking for something local, because I'm going to tackle this tonight or tomorrow... Thanks guys..
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Going for the fuel line replacement, what is available at local auto parts store, do I just use brake lines? I know you can order a stainless steel set from a vender (forgot who) but I'm looking for something local, because I'm going to tackle this tonight or tomorrow... Thanks guys.. use metric lines, I know nothing of your local area but I would not use american 5/16 or the other "pep boys,kragen or the like" equivalent to metric.. and at least where i am from so. cal. you ussually have to order the german lines or get them from an auto shop that is willing to sell as they buy bulk usually.. Hose is cheap and fuel leakes burns cars up and can injure not just you but the people driving and stareing and the guys have to put it out for you/.. Definately don't use brake hose for fuel lines or visa versa entirely different composition.. |
kenshapiro2002 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region ![]() |
Why not?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I would not use american 5/16 or the other "pep boys, kragen or the like" equivalent to metric.. Why not? Because it's the wrong size ... (IMG:style_emoticons/default/shades.gif) I'm pretty sure he was talking about the soft rubber lines ... (IMG:style_emoticons/default/idea.gif) Andy |
kenshapiro2002 |
Pretty sure he was too. I hate to be unexacting but 8mm = .310" and 5/16" = .3125". Close enough for me. Even the 10mm (.39) is pretty close to 3/8" (.375).
How come Chris makes 3/8" or 5/16" lines? How come everybody is recommending SAE sized brake lines for fuel lines? Really...just asking. The nipple off of my tank is 10mm and will go to a 3/8"fitting on my fuel pump. What would you do? I'm using 3/8" line. I would not use american 5/16 or the other "pep boys, kragen or the like" equivalent to metric.. Why not? Because it's the wrong size ... (IMG:style_emoticons/default/shades.gif) I'm pretty sure he was talking about the soft rubber lines ... (IMG:style_emoticons/default/idea.gif) Andy |
SirAndy |
What would you do? I was born metric so i'm probably the wrong guy to ask that question as you will not like my answer ... (IMG:style_emoticons/default/beerchug.gif) Andy |
kenshapiro2002 |
Don't wimp out on this...if you were born metric you;re exactly the one to answer...how would you go from a 10mm nipple to a 3/8" nipple? (IMG:style_emoticons/default/idea.gif)
SirAndy |
Don't wimp out on this...if you were born metric you;re exactly the one to answer...how would you go from a 10mm nipple to a 3/8" nipple? (IMG:style_emoticons/default/idea.gif) What would you do? I was born metric so i'm probably the wrong guy to ask that question as you will not like my answer ... I would not use a 3/8" nipple in the first place. Try some ice cubes. I hear they make your nipples bigger ... (IMG:style_emoticons/default/popcorn[1].gif) Andy |
kenshapiro2002 |
So, you wouldn't use Chris' Stainless Steel 3/8" lines? Me confused.
SirAndy |
So, you wouldn't use Chris' Stainless Steel 3/8" lines? Me confused. If there was a metric alternative to his lines then no, i wouldn't use his 3/8" lines. They are the best aftermarket lines out there that i have seen so far, but at the end of the day, i still hate to put anything in my car that's not metric. Bugs the hell out of me. Close might be "close enough" for you. For me, a close miss is still a miss. You think it doesn't matter, i think it does matter. You voice your opinion, i voice my opinion. You do what you want, i do what i want. See where this is going? (IMG:style_emoticons/default/biggrin.gif) Andy |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
If there was a metric alternative to his lines... For all intents and purposes I could call my lines metric and there would be little room for argument. (IMG:style_emoticons/default/idea.gif) My caliper measurements indicate that what I am using is so close to the factory sizes as to be insignificant, and the id is actually bigger than the original plastic lines. 8mm=.3152", about 2 1/2 thousandths of an inch different than 5/16". 9.5mm=.3743", less than a thousandth from 3/8". 3/8" and 5/16" id hoses fit very well on the fuel line connections of our cars. I just measured a fuel tank supply "nipple" at .388"od. There should be no trouble fitting a 3/8"id hose onto one. The return "nipple" measured .318"od. |
Lo-Fi Version | Time is now: 20th June 2024 - 05:34 AM |
