kpfoten |
Member ![]() ![]() Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None ![]() |
Cooler weather in Upper Michigan... Yesterday when it was warm, my '73 1.7 D-Jet seemed to idle well. Today, a bit cooler out. The car starts up and idles for 3 minutes or so (when cold) and then dies. I can start it up and if I keep the idle up I can keep it running, otherwise it will die. I'm assuming the CSV quits at a certain point and It's still not getting enough gas to keep running? I thought it might have something to do with the cold weather? Anyone else familiar with this? I will check the d-jet site (pbanders?) site now.. |
kpfoten |
Yeah, I got the correct ohm value. The resistors are also rated in watts (10, 2, 1, 1/2, 1/4, 1/8). |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Yeah, I got the correct ohm value. The resistors are also rated in watts (10, 2, 1, 1/2, 1/4, 1/8). I don't think there's a lot of current flowing through that wire, so the wattage really shouldn't matter much ... If the resistor melts, get one with a higher wattage reading ... (IMG:style_emoticons/default/biggrin.gif) Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 06:25 AM |
