V8 Water Pump Belt Woes, V8 GUYS, Water pump belt under the shift rod coupler? |
wallys914 |
Nov 27 2009, 12:57 PM
In life you don't get what you want, you get what you negoia Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California |
I have the engine installed and have already fired it up, just need to get the shifting perfect before driving, Issue.
The shift rod coming out of the car, connects to the modified shift rod, but is above the water pump belt and is pushing on it when moving through gears. I have thought of several option to rig it to work, but does any one have any ideas, as to resolve this issue? or has any one had this issue, with the shift rod Above the WP belt? Thanks |
Dr. Roger |
Nov 27 2009, 02:26 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
using the pic above as a reference point, i removed the sport mount, bolted a stock 914 back plate into the body (above the large hole in the body), and bolted the cross bar to that. clear as mud, right? =)
renegades systems have handled twice the HP and lots more weight using this system. I'm not worrying about a thing. i'll be back home later and, if no one's posted a pic, will snap a few pics and post. |
Lo-Fi Version | Time is now: 20th June 2024 - 09:16 AM |
