> Powered washer fluid assembly
swood
post Nov 29 2009, 07:40 PM
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics.
First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself.
Can I mount my pump in this area?
I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet.
swood
post Nov 29 2009, 07:41 PM
Lastly, the steering column switch. Again looking for assistance on making the wired connection.
Thanks. And yes, I'm breaking out the wiring diagrams to reference. And this is a '75 model.
Thanks.
bobhasissues
post Nov 29 2009, 08:41 PM
seemingly endless issues with my 914
I'm looking at the first picture of your resevoir, are you expecting the washer fluid will be sucked out the top of the resevoir by the pump? If this is the plan, don't count on it working. Your fluid supply has to come from the bottom of the resevoir. Also, you can fabricate your own electric switch for a few bucks using the stock switch stalk and a micro switch avilable from Radio Shack. Save a lot of money and do a search on the topic. "Spoke" had a really nice set-up and posted some photos to a thread I started on the topic several months ago. I fabbed up a homemade switch but after seeing Spoke's, I fabbed up one similar to his.
swood   Powered washer fluid assembly   Nov 29 2009, 07:40 PM
swood   Lastly, the steering column switch. Again looking...   Nov 29 2009, 07:41 PM
bobhasissues   I'm looking at the first picture of your resev...   Nov 29 2009, 08:41 PM
barefoot   Lastly, the steering column switch. Again lookin...   Jan 26 2020, 09:42 PM
r_towle   924 uses the correct switch for the column. Pump v...   Nov 29 2009, 07:45 PM
flipb   Has anyone ever stuck with the stock setup but add...   Nov 29 2009, 08:54 PM
Kirmizi   Stevo, I did this modification on my '75. I mo...   Nov 29 2009, 09:01 PM
SirAndy   I mounted the pump beneath the fluid reservoir (a...   Nov 30 2009, 01:13 PM
kconway   My car has this mod. The pump is mounted right we...   Nov 29 2009, 09:11 PM
516randy   I believe the rare factory install of the washer p...   Nov 29 2009, 09:13 PM
swood   I was thinking that if the pump went under the tan...   Nov 29 2009, 09:30 PM
davep   http://www.914world.com/bbs2/index.php?showtopic=6...   Nov 30 2009, 12:43 PM
zonedoubt   I recommend using some inline check valves at each...   Nov 30 2009, 03:42 PM
swood   Ok, i see my first error. There won't be any ...   Nov 30 2009, 10:12 PM
swood   So do I need to locate the wire that gets connecte...   Nov 30 2009, 11:01 PM
Spoke   I'm not familiar with the pink/black wire. May...   Dec 1 2009, 10:47 AM
davep   I'm not familiar with the pink/black wire. Ma...   Dec 1 2009, 01:52 PM
detoxcowboy   I'm not familiar with the pink/black wire. M...   Dec 1 2009, 02:59 PM
detoxcowboy   I suggest you read the pelican parts tech article ...   Dec 1 2009, 11:14 AM
McMark   Here's the stock 914/6 washer pump mounting ho...   Dec 1 2009, 05:49 PM
FlacaProductions   Hi All - I'm really sorry to dredge this up ag...   Jan 26 2020, 12:48 PM
914Sixer   You will have to match the wire location of the af...   Jan 26 2020, 03:33 PM
FlacaProductions   Yep. I agree. I think I finally have this correc...   Jan 26 2020, 03:58 PM
FlacaProductions   Thanks @barefoot - I have that switch as well bu...   Jan 26 2020, 09:46 PM
RickS   Wow, rather than dealing with mounting the stalk s...   Jan 26 2020, 10:07 PM
cary   http://www.914world.com/bbs2/index.php?showtopic=3...   Jan 26 2020, 10:27 PM
FlacaProductions   I've read all of the threads on this and done ...   Jan 27 2020, 09:30 AM
ctc911ctc   I just changed the wiper selector in my '74 2....   Jan 28 2020, 01:55 PM
ctc911ctc   OK, I think I guessed incorrectly.....however, ...   Jan 29 2020, 05:08 PM
FlacaProductions   that should be correctly plumbed - the one with th...   Jan 29 2020, 06:53 PM
ctc911ctc   that should be correctly plumbed - the one with t...   Jan 29 2020, 08:51 PM
SirAndy   is the tank vented so a vacuum isn't created? ...   Jan 29 2020, 09:31 PM
ctc911ctc   Yes, I have the filler cap off - biggest hole I co...   Jan 30 2020, 07:19 AM
FlacaProductions   not sure it's exactly gravity fed but i've...   Jan 29 2020, 08:58 PM
davep   So I designed a disc that was 3D printed to fit th...   Jan 29 2020, 09:46 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th November 2024 - 09:38 AM
