Powered washer fluid assembly |
swood |
Nov 29 2009, 07:40 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. Can I mount my pump in this area? I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. |
Kirmizi |
Nov 29 2009, 09:01 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Stevo, I did this modification on my '75.
I mounted the pump beneath the fluid reservoir (as per Andy's write up I believe). As for the relay, mine was already installed (yes, where you indicated) and IIRC it was for intermittent wipers. I also removed the plastic valve behind the wiper switch where the hoses connected, figured that I didn't need that anymore. Mike |
Lo-Fi Version | Time is now: 28th November 2024 - 07:38 AM |
