swood |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None ![]() |
Ok, so I'm mocking up what I have for this assembly and referencing Andy's write up
I have a few questions and I'll post a few pics. First, when I pulled out the filler tube, it basically crumbled on me. All I have at the moment are zip ties, but here's my modification. I suppose by the time I power it up, if it leaks I can get a better hose clamp. By bypassing the spare tire connection, I can run this tubing right to the pump itself. ![]() Can I mount my pump in this area? ![]() I have a new Bosch relay p/n # 0 332 019 150-010. It looks like it would go here. No clue on how to wire to it yet. ![]() |
zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
I recommend using some inline check valves at each of the spray nozzles. This way the pump doesn't have to suck fluid through empty tubing every time you operate the stalk. The factory schematics show at least on of these in use, but I haven't seen it mentioned anywhere else. PP has them in stock in their 911 section. Funny thing is the part number starts with "914-". Works well on my electric washer conversion.
Lo-Fi Version | Time is now: 26th June 2024 - 07:09 AM |
