Why doesn't my right ebrake work?, It's the asymmetric cables, dummy. |
davesprinkle |
Dec 3 2009, 10:14 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Here's why most modern cars have the ebrake handle in the middle of the car -- it's so the cables running to the wheels have identical length and path. How do I know? Here's the anecdote:
For the last year, I've been struggling with my ebrake system. The right caliper just wouldn't clamp as tightly as the left. I've got rebuilt calipers, new pads, new cables, proper clearance, but no worky. Finally found out why. It's the internal drag of the actuation cables. The passenger-side cable is substantially longer than the driver side. Also, the right-side cable has 3 right-angle bends vs the left-side cable with none. This results in so much internal friction that the cable just binds solid when it's pulled. I was able to improve the situation somewhat by lubricating the cable. Still not perfect, but much better. |
Shade Tree |
Dec 4 2009, 03:17 PM
Member Group: Members Posts: 260 Joined: 18-December 08 From: Springfield, Oregon Member No.: 9,860 Region Association: Pacific Northwest |
Don't the brake lines travel through the tunnel? This could go right next to the heater lever. You'll be done in an hour. Uh, this is DEFINITELY not for emergencies. However, if your system is in good shape, these work really well for about $200 and no more cables. I hooked one up to the front of my Samurai so I could have front and rear parking brakes. Fancy units for about $400 are electric and will work on all 4 wheels. You can put the switch right on the gear shifter.
(IMG:http://i135.photobucket.com/albums/q148/irokcrawl/CIMG0039.jpg) |
messix |
Dec 4 2009, 03:22 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Don't the brake lines travel through the tunnel? This could go right next to the heater lever. You'll be done in an hour. Uh, this is DEFINITELY not for emergencies. However, if your system is in good shape, these work really well for about $200 and no more cables. I hooked one up to the front of my Samurai so I could have front and rear parking brakes. Fancy units for about $400 are electric and will work on all 4 wheels. You can put the switch right on the gear shifter. (IMG:http://i135.photobucket.com/albums/q148/irokcrawl/CIMG0039.jpg) bad idea to use a hydro lock for any but short intervals. manufactures will not put those on manlift trucks any more. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:09 PM |
