WOW, my "solid" car aint so solid, but now it is solid!, It is off jack stands!!! |
wayne1234 |
May 5 2009, 08:32 PM
Member Group: Members Posts: 260 Joined: 6-April 09 From: indianapolis in Member No.: 10,238 Region Association: None |
Well, I decided to look into the new car more that I got from a member on here. there was a trunk floor repair that left a little to be desired. I tried using flux cored mig welding and didnt have much luck, so yesterday I got a tank and some gas @ $200 (ouch) and I was doing some survey work on the front trunk. Let me say I was way too excited to get my car and I looked underneath and saw a couple of rust throughts on the passenger side near the rear but the "longs" where I spent most of my 5 minutes looking was solid. and I though no big deal just a couple of pan spots. and under the new battery tray looked solid from the engine compartment. well under the battery tray "hell hole" was described as" not perfect". there is a piece of metal screwed over the bad stuff. making it appear solid. Then the big suprise, there has been por15 used on the motor mount I thought it looked real rough and when i pushed on it with my finger oops a hole. some poking with a screw driver resulted in the hole you see. the I looked further back at the arm that goes to the rear suspension and it is also por15 with a odd look . more poking and you guessed it a hole. I guess some one thinks por15 is structural. NOT,,, Well I dont mind documenting this because I will fix it right. but hopefully my eagerness to finally get my 914 will make someone else take a second look at the car they are looking at. Mine look great in photo's and even pretty good in person. but it had a dark secret. Now the Real question on the motor mount and (trailing arm mount?) guess that's what its called. what should I paint the back of the metal with and what gauge should I use, should I make drain holes so It wont hold water in the future? Im gonna try to do all this welding with the motor in the car. I fear I will never get the car back together if I take out the motor. Thanks for all your input. Wayne |
wayne1234 |
Dec 5 2009, 12:07 AM
Well we got the front slope nose back into shape the PO had told me that another person did one side he did the other. Hmm Well I can guess which side he did the drivers side had been barley spot welded not primed just bare metal on the underside as you can see in the first few pictures of this original post. So I wheeled it all down. re welded it, then I shaped the metal because he had over 1/2 " of bondo making the shape. (IMG:style_emoticons/default/WTF.gif) then it wasent seam sealed or anything so water got up ther and had cracked the filler I made 3 template of the curve on the other side. so I could transfer the shape over the the driver fender. It worked out great and there is only a light skim coat of filler now.. Paint will be in my furure soon (IMG:style_emoticons/default/aktion035.gif) I spent at least 8 hours on this fender today. (IMG:style_emoticons/default/smash.gif) most of that was with the body hammers and dolly.... glad thats done
Lo-Fi Version | Time is now: 23rd November 2024 - 04:53 AM |
