mike_the_man |
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 ![]() |
Hi all,
I have a couple of questions about distributors: 1) I'm putting in a pertronix, and on the old points, there was a ground strap that was connected to the bolt that holds the points in. In the instructions for the Pertronix, it doesn't mention anyhting about the ground strap. Should I use it? I can't see it being a big problem, but the Pertronix mounting plate might not sit flat if the strap is used. Any thoughts? 2) I have a 74 2.0L. On the vacuum advance there are two ports, but on the 74, only one is supposed to be used. Which port is it, and what does it do? Is there any way to test the vacuum canister to make sure that it is working? Thanks guys, |
garyh |
Member ![]() ![]() Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 ![]() |
QUOTE(mike_the_man @ Feb 22 2004, 10:27 AM) The breaker point plate seems to move freely. I'm assuming that it's the plate that vacuum advance arm attaches to. If so, it moves both ways. What does the other vacuum port do? My throttle body only has one fitting, so the advance isn't hooked up, so what is the other port doing? I'm guessing that it's a vacuum retard? Thanks, The 2nd port is a vacuum retard. It works only at idle, a (poor?) attempt to make the car pass somg checks. The ground strap comment troubles me. There should be a braid that connects the two halves of the breaker plate. If this is missing, the car will run poorly. (BTDT) Only know fix is replacing the breaker plate; all my attempts at re-welding have failed. The pertronix gets its ground through the breaker plate. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:04 PM |
