Help diagnosing Tranny leak |
RonnieJ |
Dec 7 2009, 09:51 AM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
My 75 914 was in staorage for quite a long time and now that it is out of tstorage the valves are now properly adjusted the carbs have been cleaned and in sync and it runs beautifully. I do have some clutch chatter and I have a leak coming from somewhere in the front of the tranny. I know I will have to replace my clutch disc which I have no problem doing and am wondering which seal is normally the culprit and if you have ideas could you please pass them along to me. It is hard to tell if it is Transmisssion gear oil or moto oil.
jaxdream |
Dec 7 2009, 10:40 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Ifen you do pull the trany , check your clutch fork piviot that is sometimes a leaky point as the hole for the stud goes through into the gear housing where the oil could come from, just an FYI thing, good luck.
Jaxdream |
Lo-Fi Version | Time is now: 26th December 2024 - 05:20 PM |
