Pulling the Grommet for the Fuel Lines, Is There a Trick |
kconway |
Dec 7 2009, 08:52 AM
Senior Member Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California |
I'm trying to pull the rubber "grommet" under the tank that holds the two hardlines where they go through the firewall. It doesn't want to budge but I haven't really unloaded on it yet for fear of either ripping it or not getting it back in. Is there a trick and is it difficult to get it back in?
Kev |
VaccaRabite |
Dec 7 2009, 11:12 AM
En Garde! Group: Admin Posts: 13,616 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Pull the lines out of the grommet first. That will make it a TON easier to move. You can also use some dish soap (liquid) as lubricant. Work it in with a q-tip.
If you are going to stainless lines, I found it was MUCH easier to open up the hole were the bigger tube is going to go with a drill press, otherwise it is a total bitch to get the tube back in place, especially if it is pre-flared. Is your grommet the big rubber block, or the smaller individual grommets? Mine was the big rubber block, and it was pretty sturdy. I don't know about the smaller ones. Zach |
Lo-Fi Version | Time is now: 26th December 2024 - 08:39 PM |
