Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I am checking interest in repro 904 main shafts. I think I can get them either made or made out of 901 shafts for much less than the $1800-2000 that they are commanding now.
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Best get your parts before you start. The gears ratios mentioned are scarce as hens
teeth and are priced accordingly. I've been watching for them for years and have found none used...new are made to order$$$. I finally went to the F mainshaft for first gear. You need a motor to pull it It does get rid of the cantilevered 1st, tho. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Best get your parts before you start. The gears ratios mentioned are scarce as hens teeth and are priced accordingly. I've been watching for them for years and have found none used...new are made to order$$$. I finally went to the F mainshaft for first gear. You need a motor to pull it It does get rid of the cantilevered 1st, tho. JP, you need to step into the world of rolling starts. then less motor is a requirement to use "F" as your first gear! JP has heard me say this a thousand times... but all kinds of things are possible I'm currently running F/J/S/O/V 5 useable gears to fit the needs of any track without changing the box as long as you avoid standing starts its perfectly fine... granted I'm shooting for 205hp to the wheels and will need to follow the 200hp rule also, but with a measley 2 liter that won't be a problem |
Lo-Fi Version | Time is now: 26th June 2024 - 01:42 AM |
