Eric Taylor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 ![]() |
What's the best way of installing the trigger points for the injectors? Do I need to remove the distro?
Thanks, Eric |
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,544 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
QUOTE(73/2.0 9fourteen @ Feb 22 2004, 04:29 PM) So it is ok to pull it like that? I was very afraid that I had screwed up when the drive shaft did not come out. That is a relief! Eric Yes, it's supposed to come out like that - without the lower shaft. If you look at the end of the lower shaft (or the end of the dizzy that you pulled out), you'll note that there is a notch/tab arrangement which is NOT in the center, but offset so that you can't get it mixed up. It's hard to get to the nut for removing the bracket without rotating the dizzy so to help get the timing back again, I rotate the engine so that the rotor is pointing to the slot in the dizzy case before I pull it off. Once I get the dizzy reinserted I just rotate it back so that the rotor is lined up again. It's still a good idea to recheck the timing, but the odds are pretty good that it will be dead on where it was before. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:51 PM |
