> Still fighting with the 1.7 D-jet.
kpfoten
post Dec 12 2009, 04:10 PM
--Major Edit.
AWESOME throttle response--installed a hot spark and I can get it to run really well. I think it is running rich--I hear popping but not loud backfiring. Smells rich anyway.
The problem is that it still won't hold idle unless I hit the gas pedal and keep it up around 3k rpms.
Which way do I dial the ECU to lean it out?
Joe Owensby
post Dec 12 2009, 04:34 PM
JoeO
The fuel pump should run for a few seconds every time you turn the switch on, if you have a factory control system. You can do this over and over without starting the engine. Other than this, the pump only runs when the engine is running. This is so that the pump would not keep running when it shouldn't. Example: if you had a wreck and the engine died, and a hose came loose. Big fire hazard. Stopping the pumps helps minimize fire hazards. Joeo
- Lo-Fi Version Time is now: 15th January 2025 - 03:23 AM
