Bosch Blue Coil Issues |
kpfoten |
Dec 13 2009, 04:20 PM
Member Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
Hello-- I replaced my coil a few months ago--it was no good. The new one worked until just tonight when the car died in the driveway. I am getting no spark, no reading from my timing light hooked to the coil-dizzy. My test numbers: 3.1 ohms + to - and 12.07 kohms from either to center post (this is lower than the 15-30 kohms that is the range of normal in my vw book). Key on, I get around 11.9v or so to positive terminal on the coil. Is the coil bad? Are there things that can cause the coil to fry? Confused. |
ME733 |
Dec 13 2009, 05:05 PM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
(IMG:style_emoticons/default/popcorn[1].gif) ... Nope!...the hot spark module , whatever that is , may need resetting, has a broken wire connector, or is ...BURNED out...it happens.....try reinstalling a NEW normal set of points and condenser and see what happens....Oh yea by the way...you Do have the rotor installed ...don't ya?. (IMG:style_emoticons/default/popcorn[1].gif)
Lo-Fi Version | Time is now: 15th January 2025 - 03:08 AM |
