> Bosch Blue Coil Issues
kpfoten
post Dec 13 2009, 04:20 PM
Hello--
I replaced my coil a few months ago--it was no good. The new one worked until just tonight when the car died in the driveway. I am getting no spark, no reading from my timing light hooked to the coil-dizzy.
My test numbers: 3.1 ohms + to - and 12.07 kohms from either to center post (this is lower than the 15-30 kohms that is the range of normal in my vw book).
Key on, I get around 11.9v or so to positive terminal on the coil.
Is the coil bad? Are there things that can cause the coil to fry?
Confused.
kpfoten
post Dec 13 2009, 09:17 PM
Yeah, I definitely didn't keep the ignition on. I seriously only had the hot-spark installed for 2 days and had been idling the car in the driveway for a total of 5-10 minutes before they burned up. I've heard that other people have had issues with these things.
I'd put points back in but my braided ground-wire is shot. I suppose I can change the base-plate or solder a new wire in. Ugh.
Scott S
post Dec 13 2009, 09:24 PM
Small Member
QUOTE(kpfoten @ Dec 13 2009, 08:17 PM) *
That, my freind, is what fried the unit - ask me how I know. I replaced my compufire twice before we found the problem. Car would run fantastic - then just stop. Fixed the grounding issue and have been fine ever since (1997).
- Lo-Fi Version Time is now: 15th January 2025 - 03:25 AM
