machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
Cleaned out the other side of the garage this weekend to make room for the donor 1974 2.0.
Right now I am planning on getting the following to prepare for removing the motor and starting the tear down. Parts washer Jack with > 17" lift (I have 2 that only go 13") Furniture dolly (to move motor) Anything else I might need there? Also, is the parts washer really necessary? If so, do you use the non-combustable cleaning fluid or is some kind of solvent or fuel the best way to go? Thanks, dr |
cha914 |
MUSR 8 - 5lug conversion done wed - drive 500miles thrus ![]() ![]() ![]() Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 ![]() |
Or you could go the cheap route and get a case of brake cleaner (berrimans sp? is my fav brand) and us it to clean most of the parts...If you already have an air compressor put the air blower attachment on and spray that and the can of brake cleaner at the same time, that combo can usually blast most stuff clean.
That said, I would get a blast cabent if you really wanna get stuff spotless... Good luck, Tony |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:30 PM |
