What the F is wrong with my car?, I just want to roll it off a clif. |
Eric Taylor |
Feb 23 2004, 08:29 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
So today I got the new trigger contact's installed and put the distro carefully back in, so I hopefully did not adjust the timing to far. Go to hit the key and it turns over just like a champ, hit the gas, it's a little hesatent, but run's alright, I know the plugs are black so I go to pull and clean them, thinking the car will run great with a clean set of plugs. Well I just put them back in and hit the key. The car ran crappier than ever, still spitting fluid out the exaust, still hesatating under power, like it's running super rich, which is my main problem with this piece of crap. So basicaly i'm pissed. So far I have not had a chance to drive the thing much over a mile yet since buying it in June of 03, and have replaced the following:
Entire clutch assembly Points Cap Rotor Plugs Plug Wires FI Wireing harness MPS CHT FI Trigger Contact's Set and rest the fuel pressure I'm at a total loss for what could be wrong. So here are my symptoms. The care bog's down under power, and is totally undrivable except for in and out of the garage. The plugs are Black when you pull them and there is fluid coming out the tail pipe. The only thing's I can think of are injectors, or that this engine has been screwed with so that a 1.7 injection system just plain won't work with it. I know it has been re-built in the past, but I have no idea weather it was top/bottom end or the spec's. Sorry for the long post, but I just plain don't know what to do. Help! Thanks, Eric |
keith |
Feb 24 2004, 02:48 AM
Newbie Group: Members Posts: 15 Joined: 1-March 03 From: Beavercreek, OR Member No.: 374 |
Hey, I'll drive my shitty running car halfway to Newport and we can run them in to each other. Was running ok until I fired it up to go to JP's. I wont hijack your thread I'll post my problems in another.
Keith |
Lo-Fi Version | Time is now: 22nd September 2024 - 12:10 PM |
