which pointless ignition?, best? not daydreaming this time |
tat2dphreak |
Feb 24 2004, 11:34 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
ok, with getting the new engine soon... i am looking at ignition systems...
I had/ have a pertronix ignitor in the 1.7...it worked great. but I'm thinking for the new engine, I would like a pointless system that has a rev limiter(I tend to be too rough/over rev) (IMG:style_emoticons/default/blink.gif) and that would maybe get some added performance(ie multiple or larger spark) I thought of the Crane Xr 3000(or xr 700) with an lx91 coil... has anyone used this? pertronix also has a setup that is a reasonable price(important factor) and of course, there is always MSD, compufire, etc. I have a stock 1.7 distributor, a distributor that has yet to be identified on the 1.8possibly a bosh 009... and the engine will come with a bosch 050. I would like to use 1 of these distributors... which distributor/coil/ignition system are you running? what do you suggest? |
Anton |
Feb 24 2004, 12:51 PM
Royal Orange Group: Members Posts: 161 Joined: 25-March 03 From: The Netherlands Member No.: 473 |
I also have been contemplating about electronic ignition, but decided against it. A stock set-up with normal spark plugs (no multiple electrodes), new condenser, new points, rotor (w/ or wo/ rev. limiter), cap, and leads in good condition, used with an OEM coil work just fine.
I have asked myself the question: do I NEED an expensive (and not necessarily more reliable) electronic ignition system? Is it necessary: - For modern, multiple electrode spark plugs requiring high voltage discharge? Why? Just use OEM plugs. - To replace the condenser? No, a new one just costs a few $. And normally remains in good condition for many years. - To replace the points? No, same argument. And replacing it is only necessary every 7,500 miles or so. - To gain engine power? No. This only applies to modern, high-compression, fuel injected, high-performance engines with already MUCHO horse power. A standard type 4 engine hardly falls in this category. A 0.3 (or whatever) increase in HP in a 914 will not be noticed. - For better fuel economy? Buy a Toyota (or any other rice car) Diesel (gasoline). - Better cold starting performance? Buy a new battery. I never had starting problems even during freezing cold winters. - To increase the advance curve of a tuned type 4 engine. Perhaps, depends on the make of the iginition system. But a Bosch 050 distributor also goes a long way. - To increase the value of your Porsche 914? Quite the opposite, I think. Just my thoughts... I know this is against common opinion, but thats the fun of this post. (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 06:33 AM |
