> Buick/Rover aluminum v8 to 914 conversion
streetrover
post Dec 22 2009, 09:30 AM
Hello everyone! OK, I've got an empty 914 in my driveway and a 4.0 liter Rover engine in my garage. A Buick 4bbl intake is en route as is an Edelbrock carb. I've got lots of questions about clearance, most notably about the distributor. The Rover engine came stock with a "crankshaft angle sensor" and individual coils. It'd be great to use this instead of the distributor but I don't know if I can run this ignition system without the "computer" that also controls the fuel injection. If I need to go with the distributor instead that's fine but then how do I overcome clearance restrictions? I would REALLY love to talk to someone with this conversion completed!!!
Thanks,
Bob
Cheapsnake
post Dec 24 2009, 05:17 PM
continued...
Water pump is just an empty shell. Without the wp pulley, now it's easy to see that the distributor becomes the forwardmost problem. I'm going to seriously consider the megajolt jr. to get rid of it. I love those headers, they're off a 4.0, all stainless and heat shielded.
Shot of the engine mount and cradle, all handmade, about 20 hours of work. If you can find something off the shelf, take it!
streetrover
post Dec 26 2009, 10:41 AM
It may have taken awhile, but that crossmount looks sweet!
Cheapsnake
post Dec 26 2009, 05:57 PM
QUOTE(streetrover @ Dec 26 2009, 08:41 AM) *
Thanks, if you can't find anything off the shelf you may be doing the same. I'll take some dimensions off the xmember before I drop it in, which will give you a head start on the job if you end up doing it yourself. How's your metalworking and welding skills? I like the looks of your engine mounts and would definitely build around them, if possible. I built in about 1 1/2" of fore and aft adjustment which will enable me to snug it up as close as possible to the firewall.
Where you at with your engine?
Tom
streetrover
post Dec 27 2009, 06:19 PM
'62 Buick 215 intake manifold arrived Thurs. (Xmas present to myself! -- $200). Upon initial placement it seems to fit perfectly! Carb adapter plate is on its way ($15). Trying to retrieve carburetor I lent to a friend (Edelbrock 600cfm with electric choke). Need to run by bank Monday to transfer funds for distributor-less ignition (trigger-wheels.com -- $500), adapter plate and flywheel (kennedyeng.com -- $550) external water pump (renegadehybrids.com -- $350) and 100 amp alternator (wrecking yard -- $100). At this point I feel that I am single-handedly reinvigorating the American economy! LOL!
streetrover   Buick/Rover aluminum v8 to 914 conversion   Dec 22 2009, 09:30 AM
Mark Henry   :wttc: I think some one else was doing or thinki...   Dec 22 2009, 09:47 AM
streetrover   Thanks Mark! I scanned the Megajolt site and ...   Dec 22 2009, 02:55 PM
underthetire   I use the Mega squirt II for everything. If the Me...   Dec 22 2009, 03:58 PM
Mark Henry   I use the Mega squirt II for everything. If the M...   Dec 22 2009, 06:44 PM
Gint   Never done it. But... :wttc: Post some pics fe...   Dec 22 2009, 05:59 PM
andys   Perhaps you could try to locate the correct comput...   Dec 22 2009, 07:15 PM
streetrover   I think I found that UK site you were speaking of....   Dec 24 2009, 02:24 PM
Cheapsnake   Hey Bob, just sent you an email before I saw your ...   Dec 22 2009, 07:43 PM
streetrover   OMG !!! Thanks to everyone! I...   Dec 23 2009, 01:54 AM
Cheapsnake   OMG !!! Thanks to everyone! I...   Dec 23 2009, 08:22 AM
JRust   Actually Tom to be more correct I am redoing my co...   Dec 22 2009, 08:00 PM
GS Guy   Not sure how interchangeable the old Buick V6 comp...   Dec 23 2009, 07:39 AM
streetrover   Pix I promised! I can't find my first pix...   Dec 23 2009, 05:13 PM
JRust   I like it :headbanger: . The more that do this con...   Dec 23 2009, 08:13 PM
streetrover   Exhaust manifolds... Hi JRust, while I was on the...   Dec 24 2009, 12:50 PM
GS Guy   What's the rated HP & Torque of the 4.0? ...   Dec 23 2009, 08:27 PM
streetrover   No real hot-rodding plans for motor. I want to se...   Dec 24 2009, 12:59 PM
codices   I'm in the process with a Buick bored out.030 ...   Dec 24 2009, 12:54 AM
streetrover   I looked at the reddawg site and didn't see mu...   Dec 24 2009, 01:11 PM
Cheapsnake   Let the fun begin! I hope that fine paint job...   Dec 24 2009, 06:33 AM
streetrover   THREE WEEK BACKLOG and Kennedy Engineering! D...   Dec 24 2009, 10:04 AM
GS Guy   Here are some ideas on keeping the engine short an...   Dec 24 2009, 01:11 PM
streetrover   YES! YES! Perfect! This is EXACTLY wha...   Dec 24 2009, 01:22 PM
J P Stein   OK, Iff'n I was to do a different conversion, ...   Dec 24 2009, 02:35 PM
codices   I will attempt to post a picture of the cradle...   Dec 24 2009, 03:53 PM
streetrover   That sure is a clean motor!   Dec 26 2009, 10:37 AM
Cheapsnake   Here's my version, alternator relocated down l...   Dec 24 2009, 04:55 PM
Cheapsnake   continued... Water pump is just an empty shell. ...   Dec 24 2009, 05:17 PM
streetrover   It may have taken awhile, but that crossmount look...   Dec 26 2009, 10:41 AM
Cheapsnake   It may have taken awhile, but that crossmount loo...   Dec 26 2009, 05:57 PM
JRust   It may have taken awhile, but that crossmount lo...   Dec 26 2009, 07:24 PM
Cheapsnake   [quote name='Cheapsnake' post='1255447' date='Dec...   Dec 26 2009, 08:00 PM
streetrover   '62 Buick 215 intake manifold arrived Thurs. (...   Dec 27 2009, 06:19 PM
Cheapsnake   '62 Buick 215 intake manifold arrived Thurs. ...   Dec 27 2009, 06:35 PM
JRust   I have the 600cfm with electric choke on mine. It ...   Dec 27 2009, 07:13 PM
codices   Sounds like you are coming along quite well with t...   Dec 27 2009, 08:57 PM
Cheapsnake   I am concerned about exhaust manifold/headers. A...   Dec 28 2009, 09:09 AM
pjhaun   Sounds like you are coming along quite well with ...   Dec 28 2009, 11:44 AM
codices   Tom, Are those headers fromOverland Rover Chop Sho...   Dec 28 2009, 11:12 AM
codices   Tom, I didn't read his ad well enough. He sa...   Dec 28 2009, 11:37 AM
Cheapsnake   Tom, I didn't read his ad well enough. He s...   Dec 28 2009, 06:54 PM
codices   Phillip, I think you have the pictures from some t...   Dec 29 2009, 11:32 AM
streetrover   Trigger wheels... OK, here's the latest. On a...   Jan 6 2010, 09:01 PM
streetrover   Ok, so here's the latest...I took the Rover fl...   Jan 19 2010, 08:59 PM
Cheapsnake   Am I looking at this correctly? It looks like you...   Jan 7 2010, 08:01 AM
streetrover   Am I looking at this correctly? It looks like yo...   Jan 7 2010, 08:05 AM
Cheapsnake   Am I looking at this correctly? It looks like y...   Jan 7 2010, 09:47 AM
michaelt55   Great stuff!! I have a 215 Buick engine...   Jan 7 2010, 09:33 PM
codices   Michael, Do you have any pictures? My 215 should...   Jan 7 2010, 11:35 PM
michaelt55   Michael, Do you have any pictures? My 215 shoul...   Jan 10 2010, 02:09 AM
streetrover   Exhaust Manifolds anyone? Hi guys, I'm lookin...   Jan 7 2010, 11:53 PM
Cheapsnake   Exhaust Manifolds anyone? Hi guys, I'm looki...   Jan 8 2010, 08:10 AM
codices   Bob, Didn't your original photos, in this thr...   Jan 8 2010, 02:18 PM
streetrover   Tom, Dave... I went to my local Pick-a-Part in the...   Jan 9 2010, 11:55 AM
streetrover   Here's a pick of the accordion-like manifold I...   Jan 9 2010, 12:37 PM
Dr. Roger   http://www.mgbhive.co.uk/V8-tubular-5piece-manifol...   Jan 9 2010, 02:32 PM
Dr. Roger   the last thing you want to do is bolt a couple of ...   Jan 9 2010, 02:34 PM
Cheapsnake   Good score Bob, always fun to go scrounging. Did ...   Jan 9 2010, 07:05 PM
codices   Bob, That "accordian" is probably for a...   Jan 9 2010, 07:53 PM
streetrover   Yeah, after closer measurement it is too big. No ...   Jan 10 2010, 10:01 AM
Krank   I have two 215 Olds engines. The Olds engines have...   Jan 13 2010, 12:25 PM
codices   Krank, If you have the engine mounted in your ...   Jan 13 2010, 04:57 PM
Cheapsnake   Krank, If you have the engine mounted in your ...   Jan 14 2010, 08:37 AM
andys   Krank, If you have the engine mounted in your ...   Jan 14 2010, 10:50 AM
Krank   [quote name='Cheapsnake' post='1261725' date='Jan...   Feb 19 2010, 09:31 PM
rick 918-S   Yep, that's an expansion joint. My 928 engine ...   Jan 13 2010, 06:42 PM
andys   That Olds 215 was the better motor of the two. The...   Jan 13 2010, 06:50 PM
codices   Bob, The ignition approach that you are taking so...   Jan 20 2010, 12:03 PM
streetrover   Excellent Dave! Please post as soon as you ha...   Jan 20 2010, 04:49 PM
914GT   If it helps any, I've been running a Dedenbear...   Jan 20 2010, 05:05 PM
codices   Guy, That is really encouraging to know. I have ...   Jan 20 2010, 08:18 PM
914GT   Dave, I know nothing about the Rover engines, but...   Jan 20 2010, 08:57 PM
codices   Guy, Thanks for the information. I will try to r...   Jan 20 2010, 09:01 PM
J P Stein   The Olds was the only "stock block" in F...   Feb 20 2010, 10:03 AM
rick 918-S   The Olds was the only "stock block" in ...   Feb 20 2010, 10:13 AM
Krank   Hello everyone! OK, I've got an empty 91...   Feb 22 2010, 05:15 PM
Cheapsnake   To answer your question Krank, I'm in the proc...   Feb 22 2010, 08:32 PM
Krank   Tom, Did you use an original 215 distributor or w...   Feb 28 2010, 09:31 PM
streetrover   Ok, so here's the latest... I picked up my go...   Mar 3 2010, 08:17 PM
Cheapsnake   Krank, yep, used the 215 distributor but I'm 9...   Mar 3 2010, 08:43 PM
Krank   O.K. Thanks Bob, now I'm gonna dream a little ...   Mar 3 2010, 10:30 PM
Cheapsnake   O.K. Thanks Bob, now I'm gonna dream a little...   Mar 4 2010, 07:03 AM
Krank   O.K. Thanks Bob, now I'm gonna dream a littl...   Mar 4 2010, 11:09 AM
streetrover   Got the engine in to check all the clearances. Fa...   Apr 4 2010, 12:21 PM
realred914   you might check with teh VW sand rail folks, they ...   Apr 4 2010, 02:07 PM
quick six   you might check with teh VW sand rail folks, they...   Apr 4 2010, 04:23 PM
Cheapsnake   Hey Bob, you're making progress, looking good....   Apr 4 2010, 04:43 PM
Cheapsnake   For you Rover V8 guys, here's where you're...   Apr 5 2010, 06:39 PM
streetrover   Thanks for the good words! :beer2: :beer2: ...   Apr 5 2010, 08:45 PM
streetrover   Hi Tom, You asked for a few pics of the water-pum...   Apr 27 2010, 09:36 PM
JRust   Looking good Bob! Lvoe to see what you do with...   Apr 27 2010, 09:41 PM
Cheapsnake   Nice work Bob. That plate is going to save you a ...   Apr 28 2010, 06:57 AM
codices   Good to see some progress being made. My picture ...   Apr 28 2010, 01:39 PM
codices   Let me add a few more photos--perhaps it will moti...   Apr 28 2010, 01:50 PM
codices   Just a few more.   Apr 28 2010, 01:53 PM
codices   Maybe a couple more. This last one shows the en...   Apr 28 2010, 02:02 PM
streetrover   Wow Dave - Great Stuff! GET GOING! Hey, ...   Apr 28 2010, 02:18 PM
codices   Wow Dave - Great Stuff! GET GOING! Hey,...   Apr 28 2010, 02:26 PM
codices   Help me, I can't stop. Last two. The first on...   Apr 28 2010, 02:15 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 04:22 PM
