neilca |
Member ![]() ![]() Group: Members Posts: 98 Joined: 26-July 05 From: Marietta, GA Member No.: 4,474 ![]() |
I am setting up an EP 914-6 for SCCA regionals. I have 22mm front torsion bars and 350# springs in the rear. How low can I set the ride height? I have found the bolts that hold in the front sub frame to be the lowest point of the car and I can adjust the bars till it hits the ground. The rear I use the jack points on the back corners of the tub. I can lower these down to 2" off the ground. I have a set of the 23mm front bars also and can get heavier rear springs if needed. Any suggestions? I am runing cantilevered slicks from Goodyear. I will be running tracks like Road Atlanta, Barber, Roebling and CMP. How low can I go? Thanks, neilca. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
One (of several) spread sheets I've seen give an effective spring rate of 176in/lb for a 21mm T bar at the rotor .......which is a couple inches off he centerline of the wheel. I'm not sure it's right either.
I ran a 21mm/275 set up at AX (I needed compliance) and it put the front AR bar half hard....and produced a mild ovesteer condition. Bounce your butt on the front fender then come tell me about a 117in/lb effective rate of a 22mm T bar. I ain't real scientific, but I ain't dumb. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:22 AM |
