> Questions for a 3.0, #1 is adapting to a 901, What can I keep, what do I need? what else?
Mark Henry
post Dec 27 2009, 09:20 PM
that's what I do!
Still debating to build a 2.0 or 2.4 or 2.7 or say fuch it sell it all and get a 3.0 (IMG:style_emoticons/default/confused24.gif)
To me the bottom line $$$ looks almost the same.
For a 3.0:
What would I need to keep for the clutch and PP (9bolt fly) that works on a 901?
What would I need to buy from KEP?
Should I be grabbing anything else from the donor engine ?
I'm looking a a few engines,
#1 a 3.2 that's a bit beyond my budget,
#2 an unknown 3.0 longblock core, spins fine, I suspect a broke headstud(s)
#3 a good used stock 3.0 euro sc with CIS,
#4 a hot rod 3.0 with webers newer top end w/JE's
I'm reading all the pro's and cons, yes JP.... Santa did bring me Wayne's book (IMG:style_emoticons/default/smile.gif)
What would be your order on my engine choice list above?
Cheers (IMG:style_emoticons/default/beerchug.gif)
rfuerst911sc
post Jan 2 2010, 04:10 PM
One thing you should budget is to have the stock 3.0 ignition distributor reworked to optimize for carbs. Barry Hershon ( Michigan ) or Jerry Woods ( California ) are two of the better known names that do this service. I have used both and for complete refurb either will charge about $500.00. Yes it's $$$ but I have been told that if you use a stock distributor from CIS that it's not going to run well with carbs, not sure if true but I wasn't taking a chance. I believe Henry at Supertec also provides this service. Slippery slope indeed don't even ask me how much I have invested into my GT clone (IMG:style_emoticons/default/headbang.gif) .
Mark Henry
post Jan 2 2010, 06:28 PM
that's what I do!
QUOTE(rfuerst911sc @ Jan 2 2010, 05:10 PM) *
Dizzy comes with it, but if I have to spend $500 it's Megajolt jr. or MS and run ignition only. GM coils are dirt cheap (IMG:style_emoticons/default/shades.gif)
J P Stein
post Jan 2 2010, 06:44 PM
Irrelevant old fart
QUOTE(Mark Henry @ Jan 2 2010, 04:28 PM) *
[Dizzy comes with it, but if I have to spend $500 it's Megajolt jr. or MS and run ignition only. GM coils are dirt cheap (IMG:style_emoticons/default/shades.gif)
Bad idea....trust me. MSD all the way, fat wires, & plugs gapped to .045-.05.
You do want to run it with carbs, eh?.....it took me 6 months to figure this out ....with help.
If you use the CIS cams you may get away with mega-chump.
I will explain why if you want..
Mark Henry   Questions for a 3.0, #1 is adapting to a 901   Dec 27 2009, 09:20 PM
sww914   KEP has a starter ring gear and hardware that you ...   Dec 27 2009, 09:25 PM
pete-stevers   I would/did go for an early 3.0 with cis, it has T...   Dec 27 2009, 09:56 PM
jt914-6   When I first used my 3.0 I had my 901 modified to ...   Dec 27 2009, 10:15 PM
Mark Henry   When I first used my 3.0 I had my 901 modified to...   Jan 20 2010, 01:16 PM
J P Stein   Still debating to build a 2.0 or 2.4 or 2.7 or sa...   Dec 27 2009, 10:23 PM
Mark Henry   Number 3 and 4 are the ones that I'm debating ...   Dec 28 2009, 12:13 AM
rfuerst911sc   My 2 cents ( it's all I have left after this G...   Dec 28 2009, 06:08 AM
SirAndy   KEP Stage II, Starter Ringgear, Pressure Plate, 6-...   Dec 28 2009, 11:35 AM
J P Stein   I'll accept that the Stage II set-up works fin...   Dec 28 2009, 12:43 PM
Mark Henry   What is the $damage on that set up?   Dec 28 2009, 03:55 PM
SirAndy   What is the $damage on that set up? I don...   Dec 28 2009, 04:05 PM
rfuerst911sc   What is the $damage on that set up? Here...   Dec 28 2009, 05:54 PM
jt914-6   Here's a copy of my invoice from Patrick Motor...   Dec 28 2009, 06:59 PM
rfuerst911sc   Here's a copy of my invoice from Patrick Moto...   Dec 29 2009, 06:16 PM
9146986   Get #3 or #4 with a gaurantee, and the package fro...   Dec 29 2009, 08:46 PM
Dr Evil   Did you factor in that anything over 2.7 will need...   Dec 29 2009, 09:47 PM
Mark Henry   Here's my thinking on a 3.0 :idea: I have a ...   Dec 30 2009, 07:39 AM
9146986   You can put a 24 row Mocal oil cooler in the right...   Dec 30 2009, 08:20 AM
Dr Evil   For a CIS engine you can get away with no cooling ...   Dec 30 2009, 10:42 AM
Mark Henry   For a CIS engine you can get away with no cooling...   Dec 30 2009, 12:19 PM
Dr Evil   I agree with your logic. If the 3 CIS doesnt pass ...   Dec 30 2009, 12:39 PM
Mark Henry   JP you're such a buzz kill :stooges: Man.......   Dec 30 2009, 05:20 PM
rfuerst911sc   JP you're such a buzz kill :stooges: Man......   Dec 30 2009, 05:51 PM
J P Stein   JP you're such a buzz kill :stooges: It...   Dec 30 2009, 06:08 PM
J P Stein   A cool running engine is a long running engine. Th...   Dec 30 2009, 04:14 PM
Travis Neff   You can always do the cooler under the rear trunk.   Dec 30 2009, 05:50 PM
Mark Henry   Damn...just got offered another engine :blink: 7...   Dec 31 2009, 12:37 AM
rfuerst911sc   As a point of reference I purchased a 1978 3.0 wit...   Dec 31 2009, 05:50 AM
Mark Henry   Wish I could find a sub 100K mile engine for ...   Dec 31 2009, 07:56 AM
rfuerst911sc   Wish I could find a sub 100K mile engine for ...   Dec 31 2009, 08:51 AM
Mark Henry   Wish I could find a sub 100K mile engine for ...   Dec 31 2009, 09:48 AM
J P Stein   To me it's a core, but he didn't like t...   Dec 31 2009, 10:11 AM
brp986s   I just sold a set of core alusils to EBS. They pr...   Dec 31 2009, 10:01 AM
J P Stein   I just sold a set of core alusils to EBS. They p...   Dec 31 2009, 10:56 AM
sixaddict   My experince is 3. litre (or 2.7 ) on track needs ...   Dec 31 2009, 10:26 AM
Mark Henry   My experince is 3. litre (or 2.7 ) on track needs...   Dec 31 2009, 12:04 PM
rfuerst911sc   No affiliation but just came across this on Pelica...   Dec 31 2009, 01:49 PM
J P Stein   Well, there ya go. Tack on a rebuild kit.....bout ...   Dec 31 2009, 02:23 PM
Mark Henry   Well, there ya go. Tack on a rebuild kit.....bout...   Dec 31 2009, 09:41 PM
Justinp71   I bought a '81 complete core 3.0 with a good b...   Dec 31 2009, 08:31 PM
Mark Henry   Thanks for the link but I did see it same time as ...   Jan 1 2010, 09:51 AM
Justinp71   Thanks for the link but I did see it same time as...   Jan 2 2010, 12:08 PM
Mark Henry   [quote name='Mark Henry' post='1257016' date='Jan...   Jan 2 2010, 02:01 PM
J P Stein   I don't know enough about the guts of the 3.0L...   Jan 1 2010, 10:40 AM
Mark Henry   Just the stockers, but it has a mint set of nickis...   Jan 1 2010, 11:12 AM
iamchappy   Listen to Henry.....   Jan 1 2010, 11:50 AM
Mark Henry   Listen to Henry..... Will do...damn list is gro...   Jan 1 2010, 01:45 PM
SirAndy   damn list is growing Schlippery Schlope ... :D   Jan 1 2010, 03:35 PM
iamchappy   damn list is growing Schlippery Schlope ... :D...   Jan 1 2010, 09:36 PM
brp986s   :driving: = July 2010 ... July 2011   Jan 1 2010, 04:04 PM
Mark Henry   :driving: = July 2010 ... July 2011 :chair: ...   Jan 1 2010, 04:48 PM
J P Stein   The stock 3.0L with headers & carbs will give ...   Jan 1 2010, 09:25 PM
Mark Henry   Can a mod talk to iamchappy about him posting porn...   Jan 2 2010, 02:22 PM
rfuerst911sc   One thing you should budget is to have the stock 3...   Jan 2 2010, 04:10 PM
Mark Henry   One thing you should budget is to have the stock ...   Jan 2 2010, 06:28 PM
J P Stein   [Dizzy comes with it, but if I have to spend ...   Jan 2 2010, 06:44 PM
Mark Henry   [Dizzy comes with it, but if I have to spend ...   Jan 2 2010, 07:01 PM
rfuerst911sc   One thing you should budget is to have the stock...   Jan 2 2010, 07:33 PM
iamchappy   Do something right, thats well within your budget....   Jan 2 2010, 07:58 PM
Mark Henry   Can't afford that dizzy, ya bastard, would be ...   Jan 2 2010, 08:43 PM
iamchappy   Can't afford that dizzy, ya bastard, would be...   Jan 2 2010, 09:35 PM
J P Stein   CIS is one convoluted mo fo and the SC exhaust was...   Jan 2 2010, 08:58 PM
Mark Henry   yakky yak....what ?? you guys want me to go back t...   Jan 2 2010, 10:08 PM
Mark Henry   If I did go the JE route 9.5cr or the mahle 9.7cr ...   Jan 2 2010, 10:36 PM
Justinp71   Just took my 3.0 914-6 out, man your gonna have a ...   Jan 2 2010, 11:30 PM
J P Stein   I ran pump gas with the 9.7:1 Shastas. As the man ...   Jan 3 2010, 07:36 AM
Mark Henry   Is this piece of shite any good? :idea: What...   Jan 3 2010, 12:36 PM
J P Stein   Not ehuff info for me......but that's a hell o...   Jan 3 2010, 06:35 PM
Mark Henry   mahle RSR   Jan 3 2010, 06:41 PM
Mark Henry   side http://forums.pelicanparts.com/uploads15/Pis...   Jan 3 2010, 06:43 PM
Mark Henry   Box http://forums.pelicanparts.com/uploads15/Pist...   Jan 3 2010, 06:44 PM
Mark Henry   :) http://forums.pelicanparts.com/uploads15/Pisto...   Jan 3 2010, 06:45 PM
J P Stein   No fair, I can see the draft angle at the pin boss...   Jan 3 2010, 08:08 PM
Mark Henry   Can't I shim it and get 9.5 cr?   Jan 3 2010, 08:11 PM
J P Stein   Sure, ya got 2mm of base gaskets. :D Actually, I...   Jan 3 2010, 08:20 PM
Mark Henry   Was told these are only suppose to be around 9.7 c...   Jan 3 2010, 08:27 PM
J P Stein   Was told these are only suppose to be around 9.7 ...   Jan 3 2010, 08:34 PM
Mark Henry   Ok ok..... I know it's killing you :D Say ...   Jan 3 2010, 08:51 PM
J P Stein   I assume he stuck you for +dollars for the pistons...   Jan 3 2010, 09:09 PM
Mark Henry   No cams, he never got that far into the project, I...   Jan 3 2010, 09:41 PM
Mark Henry   I have a clutch out of a 71 that I can have real c...   Jan 20 2010, 07:33 AM
Dr Evil   If I understand you correctly, just pull the flywh...   Jan 20 2010, 11:53 AM
SirAndy   If I understand you correctly, just pull the flyw...   Jan 20 2010, 12:02 PM
Mark Henry   Nope, haven't had a fall down drunk since you ...   Jan 20 2010, 12:06 PM
Dr Evil   Yup, thats what I want. As for your pressure plate...   Jan 20 2010, 12:30 PM
Mark Henry   It is a 911 71 (I think) PP and was told by the lo...   Jan 20 2010, 12:36 PM
SLITS   As a temporary fix, just remove the circlip & ...   Jan 20 2010, 12:38 PM
Dr Evil   I am not sure if it will work for a 3.0 or not as ...   Jan 20 2010, 12:39 PM
Mark Henry   I can't see a circlip and the pivot bolt trick...   Jan 20 2010, 12:55 PM
sixnotfour   poke a screw driver down to the throw out bearing ...   Jan 20 2010, 01:41 PM
SLITS   poke a screw driver down to the throw out bearing...   Jan 20 2010, 05:46 PM
Mark Henry   I know how it comes out normally, I did remove the...   Jan 20 2010, 10:42 PM
SLITS   Need the engine and flywheel on it OR some kind ...   Jan 21 2010, 10:12 AM
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 09:44 AM
