Van |
Member ![]() ![]() Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 ![]() |
I ordered a dual carb linkage kit and velocity stacks from CB performance for my 44 IDFs... 2 things surprised me - I called them, and was told, "don't worry about it - that's as good as you'll get." I'd like some other opinions...
#1: the air cleaner bases (there's a left and a right) have the same "offset" for the linkage bar - meaning the bar will be at an angle to the engine when it's installed. They said, "We don't have anything for the type 4 offset - don't worry, you'll be fine." I've seen pictures from searches, and it looks like many people have setups with a straight bar - what are they using? #2: the velocity stacks have a bore which is a bit bigger than the top of the carburetor - like maybe 3/8" larger in diameter. (Actually, the air cleaner base plate has the same large bore, too.) Anyhow, it seems to me, that if one has that large a step transitioning from the velocity stack to the carb throat, any gain from the velocity stack will be eliminated from the turbulence. CB's response, "Don't worry - you'll never feel the difference." Does anyone have any guidance for me? Should I try to get velocity stacks the right size? Should I modify the air cleaner base plates to make the bar perpendicular to the crankshaft? |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
#2: the velocity stacks have a bore which is a bit bigger than the top of the carburetor - like maybe 3/8" larger in diameter. (Actually, the air cleaner base plate has the same large bore, too.) Anyhow, it seems to me, that if one has that large a step transitioning from the velocity stack to the carb throat, any gain from the velocity stack will be eliminated from the turbulence. CB's response, "Don't worry - you'll never feel the difference." Does anyone have any guidance for me? Should I try to get velocity stacks the right size? Wow! Deja vu all over again! Years ago, and I mean years ago, I bought a dual 40IDF kit from CB and it included oversized velocity stacks. I called them up and they agreed to exchange them for the correct size, which they did. But, apparently their quality control hasn't improved much since then, or the same guy has reached his level of incompetence and is still putting together the parts for their carb kits. (IMG:style_emoticons/default/laugh.gif) They owe you the right size stacks. Give them an ear full! (IMG:style_emoticons/default/hissyfit.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 08:55 AM |
