wallys914 |
In life you don't get what you want, you get what you negoia ![]() ![]() Group: Members Posts: 190 Joined: 10-October 08 From: Garden Grove, Member No.: 9,631 Region Association: Southern California ![]() |
I got the bushings into the drop links but then when I attempted to put them on the sway bar they won't fit.
Any ideas or suggestions? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
You're doing it right. In the drop-links first, onto the bar and ball stud next. It evidently helps to drill a small hole through the back side of the bushing to let the air out, but you'll still probably use a clamp to squeeze the drop-link onto the bar or ball-stud anyway.
I've done it without drilling the hole, but it's a pain. If I tried drilling the holes, I would probably goop a little RTV on to cover the holes once I was done, just to discourage dirt from entering. --DD |
Lo-Fi Version | Time is now: 28th June 2024 - 03:46 PM |
