x98boardwell |
Member ![]() ![]() Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None ![]() |
The exhaust stud broke off. It has about an inch showing out of the cylinder (but does not have threads)..
How to remove? I know this has happened before and you will have the perfect solution so I am waiting patiently.. I know these are never easy. Remember, there are no threads left (cannot use two nuts sandwiched together) so I would like to try and get some sort of broken screw removal tool to fix... and would like to find a local alternative so I can fix over the weekend if possible. Thanks for the help in advance, Bryan |
windforfun |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,880 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None ![]() |
If it's rusted in place, try "Blaster" for starters. It takes a few hours to work. I've had good luck with the stuff.
Lo-Fi Version | Time is now: 24th June 2024 - 11:31 PM |
