x98boardwell |
Member ![]() ![]() Group: Members Posts: 62 Joined: 14-October 09 From: Central Valley, CA Member No.: 10,935 Region Association: None ![]() |
The exhaust stud broke off. It has about an inch showing out of the cylinder (but does not have threads)..
How to remove? I know this has happened before and you will have the perfect solution so I am waiting patiently.. I know these are never easy. Remember, there are no threads left (cannot use two nuts sandwiched together) so I would like to try and get some sort of broken screw removal tool to fix... and would like to find a local alternative so I can fix over the weekend if possible. Thanks for the help in advance, Bryan |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Vice grips or a pipe wrench. Heat. penetrating oil. Wrap a wet towel around what is left of the stud while you put the MAPP torch to the boss. Try to get the boss to expand while the stud does not. Turn with the vice-grips.
Zach |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Vice grips or a pipe wrench. Heat. penetrating oil. Wrap a wet towel around what is left of the stud while you put the MAPP torch to the boss. Try to get the boss to expand while the stud does not. Turn with the vice-grips. Zach You ever tried to get a pipe wrench up close and personal to a 914 exhaust stud? Or Vise Grips? GOOD LUCK! The Cap'n |
Lo-Fi Version | Time is now: 24th June 2024 - 11:45 PM |
