WTB: Plastic air deflector |
WoodOne337 |
Jan 7 2010, 09:52 PM
Newbie Group: Members Posts: 40 Joined: 3-October 07 From: Irving, Texas Member No.: 8,184 |
I would like to buy an air deflector that is attached to the pan just in front of the motor. I have attached a picture to show the piece that I am looking for. I am not sure if there is a difference between the left and right sides, but I am looking for the right side.
Thanks, Scott Attached image(s) |
c12croft |
Jan 8 2010, 01:49 PM
Member Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 |
(IMG:style_emoticons/default/idea.gif) The description is in the name, however
what function do these perform in terms of the engine's operation? |
RJMII |
Jan 8 2010, 02:32 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
(IMG:style_emoticons/default/idea.gif) The description is in the name, however what function do these perform in terms of the engine's operation? They create a turbulence, forcing air in the correct directions to assist with cooling. |
c12croft |
Jan 10 2010, 11:43 AM
(IMG:style_emoticons/default/idea.gif) The description is in the name, however what function do these perform in terms of the engine's operation? They create a turbulence, forcing air in the correct directions to assist with cooling. Where is the proper location for their install? In engine bay or beneath car near rockers as depicted? thanks, |
rascobo |
Jan 10 2010, 04:33 PM
Member Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest |
Where is the proper location for their install? In engine bay or beneath car near rockers as depicted? thanks, [/quote] They mount to the underside of the spot-welded flange where the floor pan meets the engine fire wall. You'll probably find the existing holes when You look close unless you have an early model, in which case You'll need to have someone measure theirs and let you know. Also,the side w/cross hatching faces engine compartment. Scott |
Lo-Fi Version | Time is now: 21st September 2024 - 06:45 PM |
