> Dropping Front Suspension, Check Me On This Please
kconway
post Jan 10 2010, 06:42 PM
I'm removing the front suspension complete and I've pulled all the bolts I can see and expected the whole thing to just drop to the floor. Check me on this to be sure I didn't miss something.
1. Removed the two nuts holding the struts in the trunk area
2. Removed and hung the calipers out of the way and the swaybar links
3. Removed 8 bolts underneath, 4 on the front bearing carriers, two on the rear by the torsion bar adjusters and the two holding the crossmember to the body.
4. Removed bolt from the steering ujoint coupler in the car just inside the firewall.
I think thats it, and its not coming down. Don't want to force it until I'm sure. Did I miss something? I did NOT remove the two bolts that attach the rack to the crossmember as I'm going to install turbo tie rods as well so I wanted the whole thing to come out.
Kev
Spoke
post Jan 10 2010, 08:43 PM
Jerry
I agree with Rich. Pop the tie rod ends, remove the 2 bolts that hold the steering rack to the crossmember and drop the front end. Then remove the rack.
Installation is the opposite. Replace the rack, then replace the front suspension.
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 13th March 2025 - 12:15 AM
