> Rear Fender, Remove and replace
watsonrx13
post Feb 11 2004, 06:17 PM
I've got the burnt 914 that needs the left rear fender removed and replaced. I have a parts car that has a good fender. I also want to replace the sail panel. How should I remove the fender? However you recommend, I'll use the exact same method for removing the parts car item. Once I remove the fender, I'll need to replace the door striker and some inner engine compartment sheet metal. Please be very specific and provide pics if possible. Thanks again for all of your help.
kafermeister
post Feb 25 2004, 01:32 PM
QUOTE(watsonrx13 @ Feb 24 2004, 11:13 PM)
Thanks for clearing that up Joe, from now on I'll refer to the bad repairs as the PPO (pre-previous owner - haha).
Rick, I'm trying to remove this fender as if I will use it again, it'll be good practice when I remove the fender from the donor car. Any recommendations for 'gracefully' removing the fender from the air tube?
Also, what is the purpose of this air tube, anyway?
This is what I will be doing on my car when I install the rear quarters. I am going to trim all remnants of air-tube from the 'new' quarters. I will be removing all remnants of old fender from the car itself. When I put the two together, I was merely going to tac-weld the tube to the door jam.
How does this sound to you?
watsonrx13   Rear Fender   Feb 11 2004, 06:17 PM
Racer Chris   You really need to drill out all the spot welds. ...   Feb 11 2004, 07:38 PM
watsonrx13   Is the fender and the targa panel a single piece? ...   Feb 11 2004, 09:04 PM
kafermeister   <...   Feb 12 2004, 09:17 PM
watsonrx13   Well, the intent this long 3 day weekend was to re...   Feb 16 2004, 04:01 PM
sj914   Looks like you got some 30 year old cheese in pic ...   Feb 17 2004, 03:32 AM
sj914   What does the B&D bullet drill bit look like?   Feb 17 2004, 03:33 AM
watsonrx13   Well, the removal of the left rear fender continue...   Feb 24 2004, 03:25 PM
watsonrx13   Chris (Racer Chris) you mentioned that the air tub...   Feb 24 2004, 03:26 PM
watsonrx13   The rear tail light housing has some previous repa...   Feb 24 2004, 03:26 PM
waterboy   classic thread!! :headbanger:   Feb 24 2004, 03:54 PM
kafermeister   Rob, are you removing the fender from this car for...   Feb 24 2004, 07:16 PM
Joe Ricard   Just so we get this cleared up. any reference to ...   Feb 24 2004, 07:26 PM
watsonrx13   Thanks for clearing that up Joe, from now on I...   Feb 24 2004, 09:13 PM
Joe Ricard   I'm going out on a limb here but I think it is...   Feb 25 2004, 11:23 AM
kafermeister
- Lo-Fi Version Time is now: 5th February 2025 - 08:40 AM
