> 75 fuel pump in 73 location. Needs some advise, Captn? anyone whom might have some suggestions
tod914
post Jan 9 2010, 02:19 PM
I just roughed out the placement of the 75 pump in the 73 stock location. Not the best fit. One problem the fuel filter can't be secured in the 73 filter holder. I also think the plastic lines might have to be trimmed. You guys have any suggestions? I'd rather not move it up front. Capt'n is this the way you have done it? Thanks for the help.
tod914
post Jan 9 2010, 08:51 PM
Think I found a solution without turning it into a major project. By using a set of 1 1/2" brackets attached to the mounts, then another set of mounts attached to the bracket then the pump holder, I can extend it out and pivot it. I'll post shots once I get better brackets. That should give me the clearance I need in the stock location.
914_teener
post Jan 11 2010, 10:03 AM
QUOTE(tod914 @ Jan 9 2010, 06:51 PM) *
Tod,
I am using the same pump with the same solution. post the pics when you get a chance. Just put mine on the stands last night and am taking the old pump out tonight.
Rob
tod914   75 fuel pump in 73 location. Needs some advise   Jan 9 2010, 02:19 PM
9146986   That's not the best place for the fuel pump, i...   Jan 9 2010, 04:47 PM
tod914   Thinking maybe the firewall might accomodate it al...   Jan 9 2010, 06:17 PM
Cap'n Krusty   I just put it all in so it looks professional. Wh...   Jan 9 2010, 06:18 PM
underthetire   I don't agree with the whole vapor lock thing ...   Jan 9 2010, 06:24 PM
tod914   The pump is the one from Busdepot that was on sale...   Jan 9 2010, 06:30 PM
tod914   Under, how did you attach the bracket to the firew...   Jan 9 2010, 06:33 PM
tod914   Think I found a solution without turning it into a...   Jan 9 2010, 08:51 PM
914_teener   Think I found a solution without turning it into ...   Jan 11 2010, 10:03 AM
tod914   Rob, http://www.mcmaster.com/#catalog/115/1362/=5b...   Jan 11 2010, 10:20 AM
underthetire   I actually tack welded through the holes. Easier t...   Jan 11 2010, 02:49 PM
9146986   I've had two injected 914 that had vapor lock ...   Jan 11 2010, 06:07 PM
underthetire   I've had two injected 914 that had vapor lock...   Jan 12 2010, 09:45 AM
tod914   One question on the fuel line; pump to filter. Is...   Jan 11 2010, 06:18 PM
914_teener   Tod, Ok...now I gotta laugh. Thought I'd post...   Jan 12 2010, 12:22 AM
914_teener   Ok, Finished today.....long day. Replaced the ol...   Jan 17 2010, 10:35 PM
tod914   How did you end up mounting it to the wall? Have ...   Jan 18 2010, 09:56 AM
914_teener   How did you end up mounting it to the wall? Have...   Jan 18 2010, 02:52 PM
tod914   Good luck out there, you guys are getting dumped o...   Jan 18 2010, 04:17 PM
16 User(s) are reading this topic (16 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 5th February 2025 - 02:46 PM
