Build Thread: 914 Limousine, For real this time, 914world exclusive. UPDATE: The Limo Project has found a new home! |
SirAndy |
Jan 9 2010, 08:37 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
UPDATE 04/2017:
The Limo Project has found a new home! http://www.914world.com/bbs2/index.php?showtopic=307809 (IMG:style_emoticons/default/smilie_pokal.gif) Today work has begun on the 914World exclusive "914 Limousine" project! After years of tossing the idea around, McMark, RobW and i decided a few weeks back that it was time that someone actually build such a monstrosity. RobW had a bare shell with front end damage so all we needed was another donor to make the front of the Limo. I bought a '75 roller from Chris Hamilton and Rob and i went to pick it up this morning. Once at McMark's shop in Sonoma, we started stripping the car, built a second dolly to be able to roll the shell around and started to cut off the rear of the white car and the front of the red car. Both cuts are rough cuts at this point. Next weekend, we'll start with the more detailed cutting and test fitting. The final result will be a 4-door, 4 (maybe 5) seater with at least one removable top (maybe two) and all the usual bling one would find in a Limousine. The paint has yet to be determined but we are leaning towards a certain Porsche period correct 98 color. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/beer3.gif) Andy CURRENT STATUS: - Fixed the huge hole in the front trunk floor ... http://www.914world.com/bbs2/index.php?s=&...t&p=1418688 Parts Donations: - Read here if you'd like to contribute to the 914World Limo project: http://www.914world.com/bbs2/index.php?showtopic=103595 . |
JeffBowlsby |
Jan 11 2010, 02:14 PM
914 Wiring Harnesses Group: Members Posts: 8,781 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So Andy,
Can you share any details of how this might look? Especially interested in how the roof line will work as the stock roof line/window top edge slopes down towards the rear of the car. Congrats to you and the Limo team on a cool project! Got an exterior paint color selected? |
SirAndy |
Jan 11 2010, 02:23 PM
So Andy, Can you share any details of how this might look? Especially interested in how the roof line will work as the stock roof line/window top edge slopes down towards the rear of the car. Congrats to you and the Limo team on a cool project! Got an exterior paint color selected? Jeff, we're still debating the roof. In order to create a smooth line, we need to raise the back of the front targa top and there are several possibilities. 1| We can keep the removable targa top and shim the seals to match the top of the window. This *might* look OK if we keep the targa bar side panels black. 2| Get rid of the front targa top and add a solid steel roof that can be shaped to match the door glass. 3| Leave the top shape and blend in the rear of the top with the roof strip that needs to be added between the two tops. This could be as easy as adding side skirts that 'fake' a smooth roof line ... 4| Get custom door glass. (IMG:style_emoticons/default/shades.gif) Andy PS: I'm leaning towards 2. A solid roof in the front (Maybe a sun/moon roof?) would also help adding strength to the tub. |
JeffBowlsby |
Jan 11 2010, 03:20 PM
I would lean towards option 2.) also. I don't think the stock removable top will work due to its curvature unless a curved filler is put in between the ligfted top and the door glass top edge. Even then the roof line will have an ugly 'bump' in it if the stock top is reused.
I think Felix had great difficulty with this same issue of getting custom door glass on the neo914 project. He eliminated the triangle glass, but getting custom door glass was very expensive. I don't think he ever solved it last I heard. Flattening out the top to stretch it the full length of the limo would be as straightforward as possible, but still a lot of work. I hope there is a talented metalworker available. Maybe Marks partner? Building the edges of the steel top to match the top edge of the stock door glass curvature would be the easiest approach, although still a challenge. With a solid steel top fixed sunroofs could be put in both front and rear - simple plexiglass panels using that rubber marine gasketing 'zip strip' just like the aftermarket moon roofs use. Not sure how to make a removable top panel, but this car screams for it. So Andy, Can you share any details of how this might look? Especially interested in how the roof line will work as the stock roof line/window top edge slopes down towards the rear of the car. Congrats to you and the Limo team on a cool project! Got an exterior paint color selected? Jeff, we're still debating the roof. In order to create a smooth line, we need to raise the back of the front targa top and there are several possibilities. 1| We can keep the removable targa top and shim the seals to match the top of the window. This *might* look OK if we keep the targa bar side panels black. 2| Get rid of the front targa top and add a solid steel roof that can be shaped to match the door glass. 3| Leave the top shape and blend in the rear of the top with the roof strip that needs to be added between the two tops. This could be as easy as adding side skirts that 'fake' a smooth roof line ... 4| Get custom door glass. (IMG:style_emoticons/default/shades.gif) Andy PS: I'm leaning towards 2. A solid roof in the front (Maybe a sun/moon roof?) would also help adding strength to the tub. |
Lo-Fi Version | Time is now: 28th December 2024 - 06:24 AM |
