Ian Stott |
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada ![]() |
James Smith recommended removing the rocker panels to check for rust and I am finally getting around to it, the three flat tip screws on the bottom are not cooperating and I'm resisting taking the vice grips to them, any suggestions? I ordered my new tires today, decided on the Bridgestone Potenzas, they rated very high on Tirerack and fellow enthusiasts gave them a thumbs up, will let you know my impressions after the first 100 miles, which will be at least April unless we have a warm March, which is rare, do I dare say yeah to global warming!
Ian Stott Moncton Canada |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,911 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
James Smith recommended removing the rocker panels to check for rust and I am finally getting around to it, the three flat tip screws on the bottom are not cooperating and I'm resisting taking the vice grips to them, any suggestions? I ordered my new tires today, decided on the Bridgestone Potenzas, they rated very high on Tirerack and fellow enthusiasts gave them a thumbs up, will let you know my impressions after the first 100 miles, which will be at least April unless we have a warm March, which is rare, do I dare say yeah to global warming! Ian Stott Moncton Canada soak overnight in wd 40 then heat up and hit with an impact driver. If they do not budge they will break and you will have to drill and retap them |
Lo-Fi Version | Time is now: 25th June 2024 - 12:23 AM |
