boeserbaer |
Newbie ![]() Group: Members Posts: 4 Joined: 9-January 10 From: oakland,ca Member No.: 11,217 Region Association: Northern California ![]() |
I have a 1974 2.0L. It has sat for a while, and I am trying to get it up to daily driver level. Presently my starter is intermittent. Symptom: turn key, and voltmeter drops, fuel pump cycles, no turnnover. It seems that the starter is creating a load, but not functioning. Then it will work every time for a while, then I get out on the road (bay area to LA), and my girlfriend is push starting me. On that subject I ran into the BEST porsche shop ever in torrance "callas rennsport". I vaguely recollect the same symptoms a few years ago, and replacing the ignition switch, does this sound right? If so It sucks to have to do it again so soon. I think that a relay or something is needed to reduce the current through the key switch?
Ian Stott |
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada ![]() |
Cleaning wiring connections and fuse box connections made a huge difference in my car and I have seen it recommended over and over again on this site, time consuming but no $ involved. If you still have the problem at least you know what it isn't plus you learn about your car doing it.
Ian Stott Moncton Canada |
Lo-Fi Version | Time is now: 24th June 2024 - 07:27 AM |
