High Output Electrical System, I know you guys are laughing at me |
jsayre914 |
Dec 14 2009, 04:23 PM
Speed Up !!! Group: Members Posts: 3,199 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I have 2 great hobbys, Porsche 914 and Car Stereo Sound.
I might not be faster than you guys, but I will have a very unique 914. I pulled all the stereo stuff out of my car, and I am starting all over. I just recieved my Kinetik batteries today. I got a HC1800 to replace my optima, the 1800 is rated at 1900 Amps. I also purchased a HC800 rated at 950 amps. I just found a upgrade 75amp alternator and a guy who will wind it to 120amp output to drop in place of the 55amp unit. I am going to be High Voltage! The totall draw on my stereo install will be about 120 amps at peak. I am keeping my amplifiers but building a different cabinet for the rear trunk. It will house both amps and the 800 power cell. I am ditching both capacitors that were in the trunk. The wiring will be upgraded from the alternator (Jeff Bowlsby) and I will run "0" guage from the batterys to hook togeather + to + and - to -. I will also add a few more heavy grounds from each battery to chasis and from chasis to engine. Yes there will be multiple inline fuses on the positive leads. (saftey first) I will update this thread with pics and progress as i go. (any comments) (IMG:style_emoticons/default/popcorn[1].gif) |
SirAndy |
Jan 12 2010, 02:14 PM
Resident German Group: Admin Posts: 41,813 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Any way you could have kept the cooling fins? Would seem like a good idea ....
(IMG:style_emoticons/default/idea.gif) Andy |
detoxcowboy |
Jan 12 2010, 03:19 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Any way you could have kept the cooling fins? Would seem like a good idea .... (IMG:style_emoticons/default/idea.gif) Andy There is alt. tin for the 70 amp alt. style which also hads the pulley fan, basically the 120 amp. alt is a 70 amp alt. wound to 120 amp. (vw bus bosch alt.s) The 55 amp alt. style (stock 914 and some 75 amp alt.s same body desighn) does not have the fan and the tin is diffent and will not work with the fan impeller.. Both tin styles can be found at Samba or elsewhere.. The 55 alt. tin has a smaller opening which will rub on the fan blades, where the 70 amp alt. tin has a larger opening to accomadate the fan blades.. both will mount directly to the 914 stock allighnments.. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:13 PM |
