underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
So my heat works, well, at least I can feel it on my feet or defrost. Does the heat ever come through the dash vents? My dash blower does not work, but I will get to that one of these days.
Van |
Member ![]() ![]() Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 ![]() |
Here's a question for you guys - did all 914/4s come with the electric heater blower? I'm going over my engine wiring harness, and it looks like there is a jumper in the plug instead of a wire for an electric blower.
See green jumper that goes from pin #11 to #10: (IMG:http://www.ephotomotion.com/914engine_old/IMG_0939.JPG) |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Here's a question for you guys - did all 914/4s come with the electric heater blower? I'm going over my engine wiring harness, and it looks like there is a jumper in the plug instead of a wire for an electric blower. See green jumper that goes from pin #11 to #10: (IMG:http://www.ephotomotion.com/914engine_old/IMG_0939.JPG) Jumper is fine and is factory, same as on my '74 basically instead of a seperate power and ground lead for the heater fan like in the earlier version ignition harness wiring, the jumper works as the power lead as the wiring is now seperate from the ignition harness.. I know for certain as I have converted ignition harnesses both ways.. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:32 PM |
