tomburdge |
Newbie ![]() Group: Members Posts: 33 Joined: 11-August 05 From: Hillsborough,N.J. Member No.: 4,576 ![]() |
Technical specs for Porsche 914-4 racecar.
Extensive history currently configured as SCCA F production/PCA GT6R race car. Numerous SCCA Runoffs appearances and divisional championship. Engine/Transmission Recent re-build (less then 5 hrs) 1.8 ltr, 170+hp 4 cyl. motor (dyno sheets available). Fully balanced with cr of 11.5:1 .Less then 1% leakdown. Carrillo rods, new rings ,bearings. New heads by Len Hoffman featuring ss valves, titanium retainers and extensive flow work. Lightened OEM crank, piston squirters . Proprietary cam with unobtainium ceramic lifters. Lightened and stress relieved valve train. 40 IDF Weber carbs w/K&N filters. Mallory dist ,MSD 6AL ignition box& coil.CFR/Tangerine Jet Hot Coated headers w/Phase 111 muffler. Twelve(12) qt dry sump system w/front mounted cooler & two (2) filters. All braided -10,-12 lines.8 gal fuel cell w/2 Carter pumps. 901 side shifter tranny,competition gearing and 1st/reverse lockout. Digital EGT monitor (all cylinders). Chassis: Extensive chassis reinforcement with rollcage tied to all major structural points .Raised front spindles and trailing arm PU points."Boxed & reinforced trailing arms, chassis stiffening kit, Elephant Racing bronze bearings, custom HD "A" arms, turbo tie rods, aluminum cross bar. Coil overs (all) w/dbl adjustable gas shocks .F/R adj sway bars. Adj camber/castor boxes up front. Butlerbuilt seat, ,quick disconnect steering wheel, 5# Halon bottle w/2 nozzles."Ginther" style windshield .All fiberglass DZUS fastened body panels, hoods & bumpers. About 1770# without driver. OEM Porsche "Bahama" blue w/yellow accents. Brakes/Wheels/Tires: Two (2) sets 15x7 wheels w/mounted Goodyears. Front "M" calipers w/vented disks, Tilton adjustable bias, steel braided brake lines. Spares: Wheels(see above), F/R hoods,, misc filters & tune up items, matching paint for minor repairs, useable clutch parts, some Weber replacement parts. Misc: Current SCCA/PCA log books. SCCA annual tech good till 10/10.Current F Prod record holder "Lightning" track, NJ. All this for only $15,500 (REDUCED) additional pictures upon request. Attached image(s) ![]() |
tavoman27 |
Member ![]() ![]() Group: Members Posts: 96 Joined: 13-January 10 From: Fontana Member No.: 11,226 Region Association: Southern California ![]() |
Nice car, is there an email to get in touch?
Lo-Fi Version | Time is now: 23rd June 2024 - 12:42 PM |
