Welding Saftey around Gasoline? |
detoxcowboy |
Jan 12 2010, 11:06 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Ignornat questions but..
When welding in the front trunk A.C. hole is it safe not to pull the gas tank? Full tank gas better? When welding in the engine compartment (shelf below battery where fuel lines have to be disconnected as they pass through that shelf) what do you do with open fuel lines, cap them? wet towel? Engine will be pulled so I could not just leave them connected unitl I finished?? I have no problem smoking around gas just welding is a little hot spark?? |
Rand |
Jan 16 2010, 10:06 AM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Personally, I wouldn't weld on a gas tank, even taking the proper precautions. Welding a trunk floor with a gas tank nearby though, no problem with the proper precautions. Big difference.
Lo-Fi Version | Time is now: 28th December 2024 - 05:00 AM |
