> A list of all things that could make a L-Jet Jerky, now with ............Pics of my troubled head
jsayre914
post Jan 17 2010, 01:43 PM
Speed Up !!!
I have a great daily driver. 1.8 L motor with L-jet injection, and it jerks like a son of a %^$%. It has all new vacume lines, none of wich are leaking (idles smooth at 900rpm) i have blocked off the deceleration valve. It was not letting the idle come back down fast enough for my taste. New jugs rings pistons etc. It has new plugs and wires. a new resistor pack and a newer duel relay. new alternator and new voltage regulator. Valves adjusted .006/ .008 perfectly with new valve cover gaskets. It has a new fuel pump and fuel filter, and many new wiring harness. Injectors were all cleaned and new screens put in. It runs up to 5K with no problems and runs strong to about 110mph on a flat. (IMG:style_emoticons/default/driving.gif)
Whe i accelerate easy it starts to jerk the whole way. If i try to run in 2nd or 3rd it jerks the whole time even at constant speed. sometimes i will seesaw the clutch just so i dont look to embarrising.
What is the list of things to check (i want to check everything) but i feel like i checked it all and then rechecked it (IMG:style_emoticons/default/confused24.gif)
one other problem probably related, i cant keep constant power to the fuel pump through the relay, it chokes off sometimes and dosnt want to come back (PITA) so i jumped the fuel pump lead to the + coil for now. (dont be mad) (IMG:style_emoticons/default/rolleyes.gif)
McMark
post Jan 17 2010, 01:54 PM
914 Freak!
I've had really good results from putting in a rebuilt AFM from Fuel Injection Corp.
jsayre914   A list of all things that could make a L-Jet Jerky   Jan 17 2010, 01:43 PM
McMark   I've had really good results from putting in a...   Jan 17 2010, 01:54 PM
Brando   Pull the black cover off of the Air Flow Sensor. L...   Jan 17 2010, 01:55 PM
davesprinkle   Make sure your rubber elbow isn't cracked.   Jan 17 2010, 02:08 PM
r_towle   Check the advance plates on the distributor and th...   Jan 17 2010, 02:08 PM
Bleyseng   yep, either a sticking advance plate or vacuum lea...   Jan 17 2010, 02:31 PM
jsayre914   I will have to pull the cover off the afm when the...   Jan 17 2010, 05:15 PM
zonedoubt   Sticky flapper arm on AFC. At one point, mine was ...   Jan 17 2010, 05:22 PM
jsayre914   Sticky flapper arm on AFC. At one point, mine was...   Jan 17 2010, 05:25 PM
zonedoubt   so how did you resole it? wd-40 Nope. WD-40 did...   Jan 17 2010, 06:21 PM
underthetire   I agree with the advance pate/advance springs/adva...   Jan 17 2010, 06:15 PM
jsayre914   thanks for the pic, tell me more about what i am l...   Jan 17 2010, 06:32 PM
zonedoubt   thanks for the pic, tell me more about what i am ...   Jan 17 2010, 11:57 PM
kwales   That L-jet hates vacuum leaks... And you can set ...   Jan 17 2010, 06:36 PM
jsayre914   That L-jet hates vacuum leaks... And you can set...   Jan 17 2010, 06:42 PM
jim_hoyland   I've had the jerky acceleration in my L-Jet to...   Jan 18 2010, 09:39 AM
ClayPerrine   First off.. readjust your valves. The Haynes manu...   Jan 18 2010, 11:38 AM
jsayre914   OK i rechecked the valves, alls well. I pulled th...   Jan 21 2010, 10:40 AM
jsayre914   OK i rechecked the valves, alls well. I pulled t...   Mar 24 2010, 09:49 PM
Vacca Rabite   Banging? Like clatter clatter. Or BANG BANG BAN...   Jan 21 2010, 11:19 AM
jsayre914   more like clatter clatter   Jan 21 2010, 11:23 AM
Vacca Rabite   pull the rocker cover and look. you may have just...   Jan 21 2010, 11:30 AM
type47   Make sure to relieve the tension from an open valv...   Jan 21 2010, 12:28 PM
jsayre914   UPDATE... pulled the driverside valve cover to f...   Jan 21 2010, 04:02 PM
jsayre914   :popcorn:   Jan 21 2010, 05:36 PM
Vacca Rabite   pull the pushrod out of the bore and inspect it - ...   Jan 21 2010, 05:50 PM
underthetire   Did you happen to notice if the valve was the same...   Jan 21 2010, 05:51 PM
Vacca Rabite   When you turned the motor over, did it hang up on ...   Jan 21 2010, 05:52 PM
jsayre914   I thought the valve springs all looked similar at ...   Jan 21 2010, 05:58 PM
underthetire   If it was a dropped seat, that Cyl would not have ...   Jan 21 2010, 06:02 PM
jsayre914   If it was a dropped seat, that Cyl would not have...   Jan 21 2010, 06:11 PM
Vacca Rabite   Okay, silly question, but did you have your finger...   Jan 21 2010, 06:28 PM
Vacca Rabite   Have you sent your 2L heads to have them rehabbed ...   Jan 21 2010, 06:31 PM
r_towle   Take a picture of the valves on the drivers side a...   Jan 21 2010, 07:11 PM
jsayre914   The intake valve spring on number one is not as ta...   Jan 22 2010, 12:56 PM
underthetire   The intake valve spring on number one is not as t...   Jan 22 2010, 01:05 PM
Vacca Rabite   :agree: What he said. Thats going to be another ...   Jan 22 2010, 02:08 PM
Vacca Rabite   If you get a set of the tow bar hookups, you are w...   Jan 22 2010, 03:26 PM
jsayre914   Thanks for the offer Zach, not sure what i am goin...   Jan 22 2010, 03:49 PM
Vacca Rabite   Everything can be fixed. Get the tow bar eyes. Yo...   Jan 22 2010, 04:18 PM
Kirmizi   :agree: Hang in there. You've made it this f...   Jan 22 2010, 04:22 PM
r_towle   I have done this so dont yell. Assuming you have a...   Jan 22 2010, 08:37 PM
jsayre914   i am still a newb here. Thanks for the advise rich...   Jan 22 2010, 09:22 PM
Bartlett 914   i am still a newb here. Thanks for the advise ric...   Jan 23 2010, 12:14 PM
Vacca Rabite   You have got crap compression on the cylinder at 6...   Jan 22 2010, 10:58 PM
jsayre914   You have got crap compression on the cylinder at ...   Jan 24 2010, 10:16 AM
jsayre914   Well if anyone was interested, My car is now in PA...   Jan 25 2010, 10:55 AM
Vacca Rabite   Glad to hear you made it back. I was wondering ho...   Jan 25 2010, 11:04 AM
jsayre914   Glad to hear you made it back. I was wondering h...   Jan 25 2010, 11:09 AM
jsayre914   I cannot fix my car now, because my garage is in b...   Jan 26 2010, 10:16 AM
kwales   I'd bet it is a dropped seat. The seat came o...   Jan 26 2010, 02:50 PM
jsayre914   you guessed it   Mar 24 2010, 09:50 PM
McMark   :sick: Major bummer.   Mar 24 2010, 11:51 PM
Dave_Darling   Been there, done that, got the new underwear after...   Mar 25 2010, 12:27 AM
Vacca Rabite   Did the piston survive? Zach   Mar 25 2010, 05:50 AM
jsayre914   Did the piston survive? Zach i will take some p...   Mar 25 2010, 05:48 PM
kwales   I'd recommend doing both heads at the same tim...   Mar 25 2010, 09:01 PM
jsayre914   <_<   Mar 26 2010, 09:51 AM
Vacca Rabite   Retire that engine, Joe. Its done. Its just not ...   Mar 26 2010, 03:31 PM
jsayre914   Retire that engine, Joe. Its done. Its just not...   Mar 26 2010, 03:42 PM
Brando   I agree. Start getting the parts from Jake Raby...   Mar 28 2010, 08:16 AM
Dave_Darling   Get all of the intake seats done. The other three...   Mar 27 2010, 03:29 AM
jsayre914   So now that i am running strong again... it is st...   Apr 23 2010, 01:56 PM
McMark   Are you bringing the car around to everyone? Or d...   Apr 23 2010, 03:15 PM
jsayre914   Are you bringing the car around to everyone? Or ...   Apr 23 2010, 05:42 PM
McMark   Since my humor didn't help, I still say a rebu...   Apr 23 2010, 07:31 PM
jsayre914   sooo, i have been driving everyday since hershey, ...   Apr 28 2010, 08:28 PM
Vacca Rabite   I have listened to your problem symptoms, and I ha...   Apr 28 2010, 08:35 PM
jsayre914   ClayPerrine is THE MAN!!! I just rec...   May 6 2010, 10:13 PM
ClayPerrine   ClayPerrine is THE MAN!!! I just re...   May 7 2010, 07:07 AM
Vacca Rabite   :trophy: :trophy: :driving: :headbanger: Now...   May 7 2010, 06:42 AM
33 User(s) are reading this topic (33 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 06:33 PM
